Dual 044 inline only for 1000rwhp
Hi again i did reasearch about the pumps but i found it with in tank pump , my plan is to put fuel tank in the trunk with race fuel to feed my boosted engine when racing , at the same time keeping the factory tank with pump gas with stock pump for daily use , i will put switch between the stock system and the custom one to switch between race fuel system and stock pump system this idea to save money because i like cruising in pump gas with standby system when street strip ! I now it will cost me but it will be only once then i can use it all the time , do yo think the dual bosch 044 only enough to handle 1000 rwhp ? Any btr idea ?
actually i will switch off the stock intank pump and will depend on only dual bosch 044 pumps
In no way whatsoever are 044's a gamble ( other than Chinese copies )
044 is probably the best and more reliable pump....period. And a pair will easily support 1000hp on race fuel, and quite a bit more. Nowhere has ethanol been mentioned.
Although how he intends to plumb/configure the entire system is another matter.
