New PF64?
Old 03-22-2019, 09:22 PM
KC2GIW
KC2GIW's Avatar
Default New PF64?
I saw a bunch of threads debating the merits of the PF64 vs the UPF64R BUT... has anyone seen a PF64 that looks like this? This is new to me.
Old 03-23-2019, 08:38 PM
SPIN20
SPIN20's Avatar
The one you have is the new version, the older one is discontinued
Pineapple (03-26-2019)
Old 03-24-2019, 09:40 AM
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
What changed?
C7/Z06 Man (03-25-2019)
Old 03-24-2019, 09:51 AM
KC2GIW
KC2GIW's Avatar
I wonder why the design change? I’ve never seen a filter like that before.
Old 03-25-2019, 12:58 PM
snampro
snampro's Avatar
1. go buy a bunch of the current ones from walmart (I am)
2. start conspiracy theory that this change is because something sucks about the new C8
kinda tire of Chevy changing stuff on the cars, but I can't get them to make a software update for the gauge cluster in Track mode...(go ahead, look it up, they didn't)
Old 03-25-2019, 09:28 PM
C7/Z06 Man
C7/Z06 Man's Avatar
Originally Posted by kracka
what changed?
Ditto.
Old 03-26-2019, 12:44 AM
Kracka
Kracka's Avatar
I'm guessing just a new supplier, but I still don't know what changed.
Old 03-26-2019, 03:24 AM
Pineapple
Pineapple's Avatar
Thanks for bringing this up. Just bought x6 PF64 (12640445) filters from Amazon.
Old 03-26-2019, 09:37 AM
f1reb1rd
f1reb1rd's Avatar
i sent acdelco an email waiting for replay on differance. have not gotten feed back yet 3-26-2019 but my dealer says his manual says use upf64 recommended and thats what they use in my z06 its ultraguard gold
C7/Z06 Man (03-26-2019)
Old 03-26-2019, 09:23 PM
KC2GIW
KC2GIW's Avatar
If you look at my picture, you can see a sheet metal ring around the threads with holes set up about 1/4” from the normal ring. Not sure how to articulate what I’m seeing but it’s definitely different.
snampro (03-27-2019)
Old 03-26-2019, 11:50 PM
Jeff V.
Jeff V.'s Avatar
Received 4,086 Likes on 1,971 Posts
The top part of the filter has been redesigned. Here's the old style.
And the new style posted above.
Old 03-27-2019, 01:24 AM
C7/Z06 Man
C7/Z06 Man's Avatar
Default I'll take the new one, Man.
Looks like the new filter may flow better from what I see.
The holes in the new filter are much thinner for the oil to past through AND if you look 'closely' at the old one it looks like that rubber grommet/valve 'below' the holes is also restricting oil flow (big time).
Old 03-30-2019, 10:32 AM
Zjoe6
Moderator
Support Corvetteforum!
Zjoe6's Avatar
Received 3,938 Likes on 2,425 Posts
Looks like the old one can take more torque when trying to remove a sticky oil filter. New one looks wimpy.
Old 03-30-2019, 12:52 PM
C7/Z06 Man
C7/Z06 Man's Avatar
Default Ps:
Just noticed another nice feature the new filter has in the pic that the old one does not. The new one has sealing grooves/ridges on the bottom of the filter sealing gasket.
Old 04-03-2019, 07:54 AM
ShadowGray19
ShadowGray19's Avatar
Got a couple of the new ones from the dealer. The sealing gasket may appear to have grooves in the pic but the ones I got are smooth. The metal with the holes is beer can thin but is not attached to the part with the threads used to tighten the filter. Seems like the new one will allow more oil flow that the old. It looks to me The threads are attached to a heavier metal plate below. So the new one looks "wimpy" from the top but will most likely take the same amount of torque for removal as the old one. Don't really know what to make of the changes but I think you can be sure lower cost was the motivation for GM to make the change.
The following 2 users liked this post by ShadowGray19:
C7/Z06 Man (04-03-2019), KC2GIW (04-03-2019)
To New PF64?
Quick Reply: New PF64?
