Stock 81 - Tech to Speed question
Old 03-24-2019, 06:18 PM
TO_Vette
TO_Vette's Avatar
Default Stock 81 - Tech to Speed question
I was driving around today and for some reason I'm thinking that my rpm's are too high for the speed I'm going.
I don't have any clutch slip and everything is fine but it seems I'm running higher rpm's then I remember. But maybe it's always been like this and I'm losing my mind.
Anybody with a stock 81 with a 4 speed and 350 seeing the same rpm to speed?
  • Speed Tech
  • 61 4200
  • 65 4400
  • 70 4800
  • 75 5200
  • 77 5300
Thanks
Old 03-24-2019, 07:14 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Can’t compare to my 73 auto but those RPMs do look awfully high.
Old 03-24-2019, 11:30 PM
Bikespace
Bikespace's Avatar
Received 3,132 Likes on 2,325 Posts
Don't trust any of the OEM gauges. Use a digital timing light to check that your tachometer is reading correctly, and use a phone app to check your speed (I use SpeedOverlay).
Those numbers are about twice what they should be. Are you sure you're in 4th gear?
https://spicerparts.com/calculators/...rpm-calculator
Old 03-25-2019, 01:59 AM
Antz81
Antz81's Avatar
Those rpm are well out for the speeds you say. Follow the advice already given.
Old 03-31-2019, 03:32 PM
TO_Vette
TO_Vette's Avatar
Using a speedometer app on my phone I've confirmed that the speedometer is correct. So that leads me to believe the tachometer is wrong.
Is there a sensor that can be causing this and where is it located?
To Stock 81 - Tech to Speed question
Quick Reply: Stock 81 - Tech to Speed question
