Battery
Battery
So I have a question for you. A lot of people on hear talk about that they would never put a lead acid battery in their vettes. they would only use a AGM battery. They are afraid the lead battery will crack and leak.
I'm 67 years old and have replaced many batteries here in cold Chicago, I have never had a battery crack or leak in any vehicle I owned. l have talked with a lot of guys my age and they told me the same thing. 1 guy did say he had a cracked battery but he said he dropped it by mistake.
So how many of you guys actually had a battery leak or crack?? very curious. I have used walmart batteries for a long time and have never had a leak. I was talking to some guys at acorvette show and they have the Walmart battery in their care. Said they had several and never an issue.
So I guess I would like to know how many of you ever had a cracked or leaking battery and what tpye and make was it.??
These are the first 3 hits from a quick search I just did. I definitely don't want to risk it
AGM batteries are lead acid. They just have fiberglass mats that soak up the acid. And they do leak. There was a recent post about a leaking AGM. If you are worried, get yourself a battery mat.
www.batterymart.com/p-battery-mat-black.html
When I bought my C5 I talked to a retired GM service manager about the leaking battery problem. He said most were caused when customers put their c5s away for the winter without disconnecting battery or using a battery tender. The battery would go dead and freeze, cracking the case. They replaced quite a few like that.
Received 3,812 Likes
St. Jude Donor '03-'04
There is less risk with an AGM battery also the C5 runs much hotter than any other GM Car by design. it runs in the 190 to 230 F range making the under hood temp much higher than most any other battery has to endure. So a C5 should have a battery more designed to handle the heat and not dump 16 20 20 ounces of acid on the PCM and a dozen vacuum lines and a harness
Bill aka ET
IN both cases the leak was just a seep.. and never made it down to the tray.. problem is leaking acid is very explosive,
What you do is place the battery in the tray as far forward as possible ( toward the front of the car.. then slide to the back of the tray. once seated in the back you can test to see if you got it in the right place by trying to lift the back upward.. you will know if you've got it right... Once in the rear slot you just bolt down the adjustable front hold down.
You dont have to take it out.. just take out the hold down bolt and slide it back as far as it will go, then bolt it down in the front.
I think the OEM Delco leaked and fried the PCM
When I bought the C5 it was 2 years old. I drove it 1 week and got a check engine light. The PCM under the battery was fried by battery acid. The hard vacuum line controlling the HVAC actuators was melted. The Delco battery was the reason. For the last 17 years I have been using Sams Club batteries. The last few have been sealed with no way to add any water. No leaks from any of them.
Have heard some horror stories about the overrated Optima high cost batteries. If you are scared about acid leakage spend $10 for a acid protector mat on Fleabay and put it under the battery.
Personally I have owned over 100 vehicles and had only one battery crack. It was very old and left in the car during 20 degree below zero temperatures. I have never seen a healthy fully charged battery crack or leak in the last 45 years. That being said when it was time to replace my C5 battery I went right to Walmart and got change from my $100 bill. There are only a few companies making batteries here in the US and companies like Johnson Controls put different labels on them for marketing purposes. The colorful expensive units look great at the car shows however.
Received 4,144 Likes
On my lawn tractor? yes. Almost every year.
On cars and boats no.
That being said, I just swapped out my wally world battery on the C5 for an AGM battery. Was it necessary? really probably not.
C5 of Year Finalist (stock) 2019
St. Jude Donor '19-'20
I had a dead Walmart battery so I walked in the store and bought some electrolyte. Started to pour the acid out in the parking lot and it was melting the asphalt. Took it the open battery into a laundromat and poured the acid down a metal sink OMG it shocked the holy crap out of me! Dropped the empty battery on the floor but it didn't crack, filled it up with electrolyte put the tops on hooked it up and away I went. Battery acid is nasty
I just turned 70 on the "ides of March" so I know a few things too. Not much but a few.
I do know, after reading this forum, that if a battery leaks in a C5 the acid will cause a ton of damage to the electronics.
Why chance it? Put in an AGM and forget about it.
Having said that, I'm not sure I would pull out a fairly new battery and spend the money on a new AGM but if my battery needed replacing I would certainly replace it with an AGM.
Just my thoughts,
Good luck!
Just my thoughts,
Good luck!
Im 73. Ive never had a battery crack or leak in my life. At present, I have 3 pickups and 3 cars laying around .. Ive had a lot of batteries. They just go dead. At which point I change them. Ive had a few 5th wheel RV batteries also. Actually 5. I think that I will just stick to my $120 batteries.
Received 3,054 Likes
I have the AutoCraft Platinum AGM Battery. It listed for around $179 less 30% off with their online coupon, came to $125. Do a search for Advance Auto discount codes. To me it's worth spending a few dollars more on an AGM battery for peace of mind. It doesn't matter who's name is on the case as long as it's an AGM battery.
