Grand Sport wheel options
Old 03-27-2019, 05:42 PM
Mark Maple
Mark Maple's Avatar
Default Grand Sport wheel options
My 2017 GS has had all 4 wheels bent and now one has two cracks in it. Time for something else. I see lots of aftermarket wheels advertised on this forum, but they never list a price or even a price range. This makes me assume they are more than I want to spend for wheels. What are some of my options and what's a ballpark price range for them? I probably want to keep it around $2000 or less. $3000 would be an absolute limit if I really loved them. I really like the GS wheel design. Would a reproduction GS wheel hold up better (the price should be good)?
Popular Reply
03-27-2019, 08:56 PM
Lonegun
Lonegun's Avatar
I went with these reproductions. They just looked stronger in all the right places.$1300 @ West Coast Corvette. We'll see how they hold up...
Old 03-27-2019, 06:11 PM
rangda
rangda's Avatar
At that price point you don't have a lot of options. I'm sure there is some strength variance between various cast wheels, but I'm not sure you'll do appreciably better with a different cast wheel. Flow forged is a fancy term for what starts out as a cast wheel that the manufacturer applies a process to in an attempt to strengthen them. You might be able to get a set of those towards the top end of your budget but I'm not sure. I haven't done meaningful research on them so I'm not sure how much stronger they are. Forged rims would have the maximum strength but you won't find those for $3k at all unless you get lucky with a used set (and forget $2k). You're looking at an absolute minimum of the high 3,000's for forged wheels, and the well known name brands are going to be way out of your budget.
Part of the problem is the very low profile run flat tires, the super stiff small sidewalls pass a lot of force onto the rim. If you could find a set of 18" rims that could clear the brakes and you ran non-runflats on those that would give you a larger, softer sidewall to absorb some of the impact. But even the cheapest rims + tires would be very close to or over your $3k budget.
GeoGS (03-28-2019)
Old 03-27-2019, 06:38 PM
Fcal
Fcal's Avatar
I think you can get Forgestar for under $2K
Old 03-27-2019, 06:45 PM
Zjoe6
Moderator
Support Corvetteforum!
Zjoe6's Avatar
Received 3,938 Likes on 2,425 Posts
Your budget is way too low to totally solve your problem. You need forged and they go for about $4500 for a good set.You get what you pay for. Maybe look for some used forged.
GeoGS (03-28-2019)
Old 03-27-2019, 08:56 PM
Lonegun
Lonegun's Avatar
The following 9 users liked this post by Lonegun:
Bigfoot16 (04-18-2019), Co-Vette (03-28-2019), flynbulldog (03-28-2019), Guard Dad (03-28-2019), KRamz (11-08-2019), Mike Campbell (03-28-2019), Psychodo (04-17-2019), Rebel Yell (03-28-2019), V Vette (03-30-2019) and 4 others liked this post. (Show less...)
Old 03-27-2019, 09:00 PM
Bob-G
Bob-G's Avatar
They look great on your car! Good luck, let us know how they hold up.
Old 03-27-2019, 11:07 PM
SingleTrackMinded
SingleTrackMinded's Avatar
Received 1,359 Likes on 903 Posts
subscribing to this thread for potential future reference...
Old 03-28-2019, 12:21 AM
Chadrad
Chadrad's Avatar
The very first thing you should do, if you haven't already, is get the Mag Ride Calibration Update. It will make you believe that your car actually has suspension. In my opinion, the original calibration is a major contributor to the wheel bending/cracking issue. Before the update, I was beginning to think I was going to have cracked teeth to go with my bent rims. After the mag update, get yourself a set of Vorsteiner Flow Forged. I got a set of FF-103s in Carbon Graphite for $1700 from Vibe Motorsports. Normally $2400.
The following 2 users liked this post by Chadrad:
Gearhead Jim (11-08-2019), KRamz (11-08-2019)
Old 03-28-2019, 01:32 AM
geewez
geewez's Avatar
Replacement wheels or not it’ll happen again. Factory reproductions will be the same problem because of the design of the wheel and the run flat tires. Finally figured out the cause of the rear cracked wheels: very wide wheel (12”) ,very little sidewall and stiff inner design of the factory run flats to help absorb the imperfections in the road. If you cut open a run flat tire you’ll see that there’s a stiff almost solid inner sidewall that is designed to hold up the tire in case of a flat. That’s why all the cracked wheels are always in the same locations and mostly in the rear. GM won’t acknowledge the flaw because it’ll cost them millions if not hundreds of millions of dollars. I spoke with one GS owner who went through four replacement wheels. I’d recommend everyone who’s gone through this to go to the NHTSA web site and fill out a complaint form regarding cracked and bent wheels. Maybe if there’s enough complaints they will investigate and force GM to make a recall or reimburse owners who have had to replace wheels out of pocket. For now it’s better to spend the money on a good forged aftermarket wheel and a set of non run flats. You’ll get a stronger wheel and a quieter ride. Get a flat? Call AAA.
Dale002 (02-25-2021)
Old 03-28-2019, 09:22 AM
Zjoe6
Moderator
Zjoe6's Avatar
Buying el cheap o rims is probably not going to solve the problem. I hope I’m wrong but usually you get what you pay for in this world.
Old 03-28-2019, 09:30 AM
Mike Campbell
Mike Campbell's Avatar
Received 1,067 Likes on 591 Posts
I've bought reproductions over the years from WCC, DocZ and House of Wheels and they've all been excellent and they're all Forum vendors. So I wouldn't hesitate to buy from them and actually I'm looking at the ZR 1 style wheels now. Just saying!
Rebel Yell (03-30-2019)
Old 03-28-2019, 09:32 AM
New World Matt
New World Matt's Avatar
Default Damn dude !
Those ZR1 reproduction wheels look awesome !
Let us know how they’re holding up - and post more pics please ! If I ever crack a wheel , I’d like to see those sweet chromes on my black 2017 GS .
Lonegun (03-28-2019)
Old 03-28-2019, 10:25 AM
Maxpowers
Maxpowers's Avatar
Received 2,729 Likes on 1,829 Posts
I have to disagree with some folks that say you have to get Forged.
Forged are the best and you pay a premium for that. But a good quality set of Rotary Forged wheels will suit daily driving purposes just fine. I bought a second set of Cray Spiders. Paid about $2000 and they come with a 5 year warranty. Few if any comments on the net about these wheels cracking / bending.
Old 03-28-2019, 11:26 AM
Dado5
Dado5's Avatar
Yep i am looking for wheels also since i have 2 bent on my GS. I think any wheels other than OEM made in china will be better. Im looking at forgestar, Vorsteiner, Cray and MMR.
Old 03-28-2019, 02:52 PM
Rebel Yell
Rebel Yell's Avatar
Received 2,639 Likes on 1,702 Posts
I bought a set for my previous '16 for DOCZ. After three years, and 12K miles they looked as good as new.
Old 03-28-2019, 03:05 PM
Lonegun
Lonegun's Avatar
I bought those in November along with the AS3+ZP's. Daily drove all winter (Texas winter). Still straight, uncracked, and sparkle like new. Just seemed to me that it was a question of when not if they were gonna cause an issue. I just figured if they're gonna bend anyhow from poor engineering, might as well bend the "cheapos". I'll hold on to the black stock units until I trade her in in a couple of years and swap em back then.
Rebel Yell (03-29-2019)
Old 03-29-2019, 10:47 AM
Bob-G
Bob-G's Avatar
For anyone not already aware, there is an aftermarket wheel thread where you can check out what wheels others have purchased, and post what you have purchased.
https://www.corvetteforum.com/forums...-thread-9.html
The following 3 users liked this post by Bob-G:
DreamMachine7 (09-25-2019), Rebel Yell (03-29-2019), SlasherMcGee (03-29-2019)
To Grand Sport wheel options
Old 03-29-2019, 01:13 PM
96GS#007
96GS#007's Avatar
Received 1,739 Likes on 1,047 Posts
I agree with Maxpowers. Aftermarket cast wheels have been fine on the street for many years. The drawback is weight. They're often 3-5 lbs heavier....per wheel. My personal belief is that the Corvette team over-rotated trying to save weight and when combined with the runflat tires, the wheel barrels are simply too thin.
The following 2 users liked this post by 96GS#007:
Maxpowers (03-29-2019), Wideout (07-12-2019)
Old 03-29-2019, 01:20 PM
Prray
Prray's Avatar
Wow, those look great in chrome!!!!!!
Old 03-30-2019, 01:07 PM
Rebel Yell
Rebel Yell's Avatar
"Lonegun" more pictures please.
Quick Reply: Grand Sport wheel options
