Sliding all over the road - rear end
I have a 2015 stingray, has 45,000 miles on it.
If I hit a bump or join (like bridge) in the road, crack, uneven surface the car skates all over the road, like on ice (mostly felt in the rear section).
Things i have changed:
- to z51 sways bar and aFe Control PFADT Series Heavy Duty Street End Links
- to z51 shock (non electronic - less than 8K miles on vehicle)
- lowered vehicle on stock bolts all the way down
Notes: the issue mentioned above was not present after this upgrades
Things i have done:
- my front two tires were bad, so i had to get new front tires (same as factory)
- new alignment (see attachment)
- I noticed a crack in the ball joint bushings rear right, so
- Jacked the car up and then put my hands in the 12 and 6 positions of each wheel and see if i could rock the wheel back and forth vertically - (nothing happened - was steady and firm)
- i recheck the adjustable Sway bar End Links ( was good )
- 30psi pressure (good)
Can any one help or give me some feedback and things i should check or missed?
Thanks
Things i have done:
Thanks
You just saidnthe issue isn't present anymore....
@BrunoTheMellow yes the issue is still present
Bet ya anything it’s rear caster. My was spot on then dealer did an alignment and had it out 2 degrees. Huge vette dealership but as usual didn’t know nota about rear caster!!! Had to have shop make a gage and did it for them!!! Dealers suck sooo bad!!!
Rear control arms could make it sway, if the bolts are loose, or the Bushings are bad.
z51vett (04-25-2019)
So I started removing and putting back stock components as suggested and I found the culprit while doing this, the lower arm control is leaking oil and the boot is cracked definitively in bad shape, I ordered the replacement parts.
i removed all the bolts except this section, is this section hard pressed, I tried with a spry bar and nothing with a rubber hammer and nothing any suggestion? See photos
A leaking boot won't cause you to slide around. Yes... Your spindle lower bearing is pressed in.
You should take it to a professional. Sounds like you need to do some more research before trying to pry stuff apart.
One problem is your dropped all the way down. The lowering bolts are meant for corner balancing. If your all the way down your taking out to much suspension travel, which will cause you to lose traction faster. Fix your caster and give your suspension it’s range back. Slammed cars handle like crap.
Edit: see you found a leak. I still recommend bringing the car an inch and then getting your caster set correctly for optimal handling.
i disagree. Going to low does affect traction at the limit as we have moved the limit. In my opinion, all the way down on stock bolts looks great but does sacrifice grip. A good test, run some laps corner balanced and then again slammed on the stock bolts. Lap times will suffer, a lot.
jonparks (05-19-2019)
dsword (05-26-2019)
Get your caster set I speak from experience my Z06 kept trying to pass me.
z51vett
Doug
z51vett
Doug
dsword (05-26-2019)
Eismann’s Corvette Center in Jupiter, Florida can properly align your car if you haven’t fixed already.
Except you effectively have no suspension for the first inch of travel.
Sr.Random input generator
I'd also recommend raising the car. Your suspension needs more travel to handle those shocks you run into at the bridge.
Did you end up giving your issue?
