Hidden speakers in rear with hidden sub!
Old 04-21-2019, 10:55 AM
CAMS69
CAMS69's Avatar
Default Hidden speakers in rear with hidden sub!
Not sure if anyone out there wants an upgrade stereo with a little sub, speakers in the rear AND no use of any very needed space for t tops, rear window and luggage?
later this week I’ll post a pdf if the template I cut for the rear speakers. The template kinda shoves to the back into that cravas back there. PLUS added bonus the sub seems to fit under passenger seat!! More updates as they unfold.
Old 04-21-2019, 12:15 PM
CAMS69
CAMS69's Avatar
Default Rear window stowage operable.
Old 04-21-2019, 12:37 PM
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
Sub under passenger seat. Using the bass for foreplay?
Old 04-21-2019, 02:06 PM
CAMS69
CAMS69's Avatar
Default Bass for the ladies.
Yes. I have it in two other cars under pass seat ... trust me it works!
platinummaker (04-21-2019)
Old 04-21-2019, 03:47 PM
JohnRR
JohnRR's Avatar
I would like to see the templates for the speakers.
Thanks for sharing!
John
Old 04-21-2019, 06:17 PM
wendellp601
wendellp601's Avatar
Old 04-21-2019, 09:17 PM
KaelFarmer
KaelFarmer's Avatar
Does that sub fit under the seat without modifications to the floor? How much room is there actually under the seats?
Kael
Old 04-22-2019, 09:58 AM
PainfullySlow
PainfullySlow's Avatar
Thanks for posting this! I made an enclosure myself that *should* fit in the back without interference for the rear window tray but if not, I am absolutely borrowing this idea! Nice, clean work and thank you for sharing!
Old 04-22-2019, 11:00 AM
CAMS69
CAMS69's Avatar
Default Here you go...
Ok the template is made to be printed on 8 ½ x 11 standard paper.
There are 4 pieces you will tape together after printing. The pdf is actual size so when you print it do not (scale) or( make it fit)
Just print 100%. After printing you can check the 1” mark i left for you. Tape all 4 together and cut out of 3/8” plywood.
Once the material is wrapped to the front and back it will make this piece even thicker and tighter in that cravas in the back of the vette.
I noticed if you put the speaker in first ( and it’s to low and it’s to big) it become almost impossible to slide this in. Rear window storage tray
will work nicely, but not if your speaker sticks out much..Remember hand built cars, so not all the same, you may need to tweak..
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
JohnRR (04-22-2019)
Old 04-22-2019, 11:01 AM
CAMS69
CAMS69's Avatar
Kael
Yes!
Old 04-22-2019, 10:08 PM
VetteLooking
VetteLooking's Avatar
Thanks for posting the speaker template. I may try that next winter.
I used the right rear storage for that sub.
Old 04-23-2019, 07:02 AM
CAMS69
CAMS69's Avatar
Default Awesome!
[QUOTE=VetteLooking;1599274419]Thanks for posting the speaker template. I may try that next winter.
That was my first choice. I was worried stuff on there would vibrate?
[/QUOTE
Old 04-23-2019, 04:38 PM
JohnRR
JohnRR's Avatar
I really like this too! Thanks to both of you for sharing your very clever solutions.
John
Old 04-26-2019, 05:45 AM
DorianC3
DorianC3's Avatar
subscribed
To Hidden speakers in rear with hidden sub!
Quick Reply: Hidden speakers in rear with hidden sub!
