2013 C6 AC/Clock display blank no AC
I have a 2013 Grand Sport 2LT. I've had it for about two months and it has 27k miles. I encountered a problem about 3 weeks ago one night where I started the car and the AC/Clock display was blank. None of my ac controls worked, the Navigation and radio worked fine though.After driving about 20 minutes, the display came back up and everything worked perfectly. It happened again this morning so I left it parked. Is this an early sign that my AC unit is about to go out?
The C6 corvettes are noted for having HVAC control unit issues. The screen goes blank, or the display starts flashing. My 07 Pace Car did the same thing as yours about a year ago, but so far the display is still working. However, my AC quit working several weeks ago. The AC compressor clutch is not engaging. Both the AC fuse and relay are good. Need to put gauges on the lines and check the static pressure. I might have a Freon leak or the compressor detonated.
Everything AC wise works the way it should when the screen is displayed, it just doesn't work when the screen is blank. I haven't checked my fuses yet. I'll have to do that this afternoon.
