Rocker panel body damage
Has anyone ever had damage on the rocker panel fixed? I got some damage on mine (recently bought car, not sure how this happened) and today got a quote to get it fixed. I was quoted a little over 5k to replace the rocker and repaint.
The quote included blending on the QP, but if anyone has had one of these replaced and repainted can you let me know cost and where you had it done?
Thank you!
Thank you!
Received 1,738 Likes
St. Jude Donor '15-'16,'18
My passenger side rocker panel was replaced when I scraped a piece of concrete in a parking lot. Insurance paid for it. I think it was around $3500. Paint is a perfect match. Todd Auto Body in Greencastle PA did the work. Very pleased. Installed side skirts to prevent future damage.
Moderator
Received 3,748 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
Expensive to replace lower is glued to the frame. A good shop should be able to easily repair and paint it perfectly.. it's not like it's steel good luck, sux having a ding
The following 2 users liked this post by Gixxerman:
Glennm27 (05-20-2019),
joemessman (05-21-2019)
Given the location a set of side skirts might hide 80% of the damaged area.
Received 1,407 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
$5000 is insane.
Get it repaired and painted on the car.
That can be blended on only the rocker. No need to blend a panel that low on the car up onto the quarter. They would have to clear coat the entire quarter to do that. Screw that. Stay off the quarter.
The following 2 users liked this post by Glennm27:
obxchartercaptain (05-21-2019),
Vegas1500 (05-21-2019)
Received 19,300 Likes
'20-'21-'22-'23-'24
I agree with Glenn - a repair like that should not cost anywhere near $5K. Find another body shop and get a quote.
Gixxerman (05-20-2019)
Moderator
very repairable at that location.. I can't see needing it completely replaced.. big job getting old one off glueing and getting fit right.. repairing will be fine with less chance of breaking or damaging some other part. I would then put side skirts on.. better to have them as a sacrificial offering to the concrete gods.. If replaced you'd still be repainting anyway and color may not match if painted off the car. 5k seems awful high.. or the guy quoting you is.. good luck whatever route you take.
Looks like I am going to get an additional quote this weekend! I didnt think 5k seemed right, I want it fixed correctly but dont feel like all of that is necessary. I looked over the quote, it was 5,347.29 all said and done from this shop. They are very high end. Chevy recommended caliber collision but I am hesitant to take it there.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
But for that minor damage, crazy, IMO! They have a Bondo for plastic. Most C7 panels, like this one, are plastic composite with ~40% fiberglass. If it were steel thay would use Bondo for metal. Considering where it is, way below eye level, a good painter should be able to match without going over to fender. Then put on side skirts and you'll never know it was damaged.
Moderator
Ouch.. just when the nightmares of jacks went away...you bring it back aaarrrggghhh I hate those pics.. make my skin crawl
Just watch the jack saddle/jack pad position after each pump! No problem!
Easy "If you do what I say and not what I occasionally foolishly do!"
ha I ordered jack pucks to avoid that issue, should be okay there hopefully! I am going to get a few more quotes. I already had side skirts on order, may just see how much they will "hide"
Received 3,439 Likes
I think the recommendations to have it repaired is the way to go. A good body shop can do that for less than a grand and it'll look like new.
Note after my short arm jack slipped at it's max lift (where it would have to move in 2.6 inches to stay centered) -cracking a side skirt (because I didn't follow my own advice of being sure the jack saddle is still centered on the jack pad after each pump) I bought a long arm jack "thinking that would reduce the issue." However that 95 pound jack was not moving into the car center "at all" on my tiled garage floor OR on my concrete driveway where I often change oil!
The jack saddle had a very shallow lip (probably to have a wide lift range) so I welded on 3/8 inch high lip so it could NOT slip. That also helps pull the jack into the car! Just be sure: 1) the jack saddle starts centered on the jack pad; 2) the jack is perpendicular to the car; 3) if it has rear casters align them to be ready to move in and 4) AND look at the jack saddle/jack pad alinment after each jack pump!
