Honking horn
Old 05-23-2019, 03:38 PM
bdodge
Cruising
bdodge's Avatar
Default Honking horn
I know that I saw the fix for this awhile back, but cant find it now.. All of a sudden, started today, when it enter my car and close the door the horn honks twice.. Simple fix I'm sure... Thanks..
Old 05-23-2019, 04:13 PM
Landru
Landru's Avatar
Received 1,045 Likes on 819 Posts
On C6 it's covered under "Auto Lock" features/operation in owner's manual.
Same w/ C7 I'd guess.
Horn honks if it's set to, turn it off & you're golden.
Or, should be.
Old 05-23-2019, 04:59 PM
owc6
owc6's Avatar
Received 4,185 Likes on 2,679 Posts
While Landru is telling you something true, the car is honking at you for a reason.
Before you turn off the notifications, it might be wise to find out what it's saying. Can you give us both your exiting and entering scenarios? I doubt it's about a fob, though, because that is usually three honks.
I, also remember a thread about only two honks recently. I don't remember what the upshot was, however.
Old 05-23-2019, 09:00 PM
bdodge
Cruising
bdodge's Avatar
Car is a 15 stingray, 2lt.. Only heard the 2 honks, twice. It has now stopped.. It happened when I entered the car and closed the door. ??
Old 05-25-2019, 01:57 PM
Rich0071
Rich0071's Avatar
My seems to honk twice when I have the fob in my pocket, open my door to fuel leaving the door open, and then getting back in and closing the door. I'm sure its some software setting. I believe if I close the door when fueling and get back in it doesn't do this.
Old 05-25-2019, 03:25 PM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,066 Likes on 6,168 Posts
If you leave the door open after exiting and the renter and close the door it does the two honks to warn you that you have left the fob in the vehicle. It does not take into account that you are sitting in the car. It simply knows the door was opened and now is closed and there is a fob in the vehicle.
Old 05-25-2019, 04:18 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
Agree with this but there are 3 Es in reenter. Also might need an "n" on the "the". Your brain is typing faster than your fingers.
Elmer
Old 05-26-2019, 10:13 PM
bdodge
Cruising
bdodge's Avatar
Thanks for all of the info.. That is exactly what happened. I got out and refueled and left my door open, with fob in my pocket. Honked twice when I reentered.. Thanks again..
Old 05-26-2019, 10:43 PM
Mad*Max
Mad*Max's Avatar
Received 1,494 Likes on 815 Posts
You can start the car before closing the door to avoid the honk.
Old 05-27-2019, 12:54 AM
Skid Row Joe
Skid Row Joe's Avatar
Received 3,963 Likes on 2,873 Posts
Nope. My fob is in my pocket and I get the two horn beeps on occasion only in my home garage. No idea why. Just is. Second key fob is 35' away in my kitchen from the garage..
Old 05-27-2019, 10:01 AM
owc6
owc6's Avatar
This scenario is always a triple honk. All "fob left in vehicle" situations are. It's a very fast three, however.
Old 05-27-2019, 11:00 AM
yellow2007
yellow2007's Avatar
Received 1,076 Likes on 630 Posts
I get one honk after about 15 seconds of exiting the car and closing the door. Makes sneaking in the house kinda difficult.
To Honking horn
Quick Reply: Honking horn
