Has anyone been able to delete ice mode out of C7?
Old 06-18-2019, 08:41 AM
savage
savage's Avatar
Default Has anyone been able to delete ice mode out of C7?
I知 very tired of Ice mode and I知 going to get hurt one of these days , I知 on my 4th c7 and everyone of them go into ice mode going from wot to stabbing the brake pedal! I知 looking for someone who can reprogram the ABS before it Kills me, please no discussion if it痴 real or when it happens I知 just looking for a reprogram on ABS . Thanks
Old 06-18-2019, 08:55 AM
rrsperry
rrsperry's Avatar
Received 1,412 Likes on 737 Posts
Learn to brake better? I think stabbing the pedal might have something to do with it. I once took a ride with Sir Jackie Stewart, you seriously couldn't tell when he started to brake or use the gas. VERY smooth... Yet he braked HARD... He said, apply the brakes and gas gently, then give it the beans.
Old 06-18-2019, 09:12 AM
savage
savage's Avatar
i understand that< in autocross where every hundredth of a second counts you brake late and hard. the run is over in 1 minute im not saving tires or brakes for a 20 minute run what im doing is fighting for every second ! im sure you know in autocross there is no coasting your either on the gas hard or braking hard. you would be surprised how many autocrossers and track rats have this problem> if you google it their are dozens of posts on it > im sure someone is going to be able to reprogram the ABS sooner or later . i dont know how to post this past weekends event of my mishap at ponoco but your welcome to watch it and post it if you can > facebook is david savage , swoyersville pa, lion brewery thanks its the first video on my page , im going from 88 mph to standing on brakes that are only giving me 30% ??
Old 06-18-2019, 09:38 AM
Bigredwing
Bigredwing's Avatar
Sorry I have no answer, but maybe you can educate me on autocross or what you are experiencing. If I understand, you are at WOT and then hit the brakes to make it around the course. At this point the driving mode senses the change in inertia and changes to Ice Mode? What mode are you in when autocrossing before it changes? Seems to me in Track mode or higher it should never change. This is the first time I've heard of your problem. Hopefully somebody does have your answer.
Old 06-18-2019, 09:48 AM
savage
savage's Avatar
google C7 ice mode problems , your going to be surprised how many guys are dealing with this and crashing their cars in all c7's all modes track , sport and tour!! their has been many threads on this with no fix !! their was even a ask TADGE thread where he skates around the answer thats there is no fix !!
Old 06-18-2019, 10:26 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
Support Corvetteforum!
JerryU's Avatar
Received 9,598 Likes on 6,612 Posts
Thanks for an understanding of why this is important to you! Just read the Tadge answer, since you referenced. Didn't sound like he "skated the issue," just explained the complexity of the ABS re various "normal" (and even tracking) needs, even in PTM.
Sounds like in your case (for Autocrossing) you'd be best to eliminate ABS? Can't a "tuner" do that?
Perhaps a dumb question, but even if it trips a CEL can you "unplug the ABS" or will the car not operate?
Old 06-18-2019, 11:01 AM
The HACK
The HACK's Avatar
Autocross? Learn to left foot brake if every tenth is THAT important, so you can save the tenth of a second from transitioning to the brake pedal, and avoid the SECONDS you壇 lose by stabbing at the brakes.
99% of a car痴 performance problems can be solved by fixing the nit behind the wheel.
foot 1 (06-19-2019)
Old 06-18-2019, 11:47 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Reprogramming of the ABS won't be done any time soon unless one of the engineers that worked on the original calibrations decides to retire and offer their services to retune the ABS. Retuning the ABS isn't as simple as making some adjustments in a table like engine tuners do. There are a lot of variables that have to be worked with to make sure the ABS remains safe. If you want to have a resolution to your problem sometime during your lifetime I suggest you try braking differently (a quick but soft initial application of brakes followed by swiftly increasing force on the pedal. That way you don't get the initial slam on the pedal but are able to apply full force within milliseconds.
Bill
Old 06-18-2019, 11:48 AM
savage
savage's Avatar
thats exactly what im asking in this thread , someone who can reprogram my ABS , im sure someone will figure this out and make $500 or 1K for program . did you happen to go to my facebook page and see me blow off the track ? david savage , swoyersville pa. lion brewery - thanks
thanks bill i've always respect your opinion, i have been autocrossing since 1990 and now at 58 years old i need to change my braking ( wish me luck) sad thing is i had 11 corvetts before my c7's and never had a iceing issue !! as you know corvettes are crashing because of this , sooner or later someone will get killed and it will be on the PDR and then TADGE will fix it ! thanks again for your time and im surprised how few people know of C7 ice mode. i've never experienced either on a corvette club ice cream run !
thanks ( the hack) for your input , did you happen to watch the video on my facebook? its not fun and someday it will happen on the street to someone who gets hurt , and yes i am a nut behind the wheel but thats no excuse for ice mode on a dry day ! thanks again
Old 06-18-2019, 12:20 PM
rogergcam
rogergcam's Avatar
Not being a racer, would someone explain what icing mode is?
Old 06-18-2019, 12:43 PM
TXshaggy
TXshaggy's Avatar
Received 1,093 Likes on 608 Posts
You on stock tire, brake, suspension, etc. ?
Old 06-18-2019, 12:49 PM
TPAJETSKI
TPAJETSKI's Avatar
Me too.
I initially thought OP was talking about when the DIC tells you to be careful because ice on the roads is possible.
Old 06-18-2019, 01:05 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
I think its just an odd term for "ABS activated" (maybe regional?). I've been in Corvettes for 30 years (yes in auto-x too) and this is the first I've heard ABS activation called "Ice mode"
Old 06-18-2019, 01:13 PM
Maxpowers
Maxpowers's Avatar
Received 2,722 Likes on 1,826 Posts
There have been a few threads on this and i haven't seen a solution you're looking for. Im guessing there arent many that drive to the precision you and a handlefull of other folks do to kick in ice mode. Maybe a vendor will step up to the plate if others are noisey on this.
savage (06-18-2019)
Old 06-18-2019, 01:15 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
What tires are you running for auto cross? Do you have a more aggressive brake pad?
While "ice mode" is 90% driver induced, changing tire sizes definitely has a negative impact on how sensitive the car is to pounding on the brake pedal. As an avid auto crosser that usually does very well, I've worked with a lot of people on changing their braking habits in modern cars. Aside from aftermarket (Bosch Motorsport) ABS systems, very little can be done to the stock system to reduce ice mode.
savage (06-18-2019)
Old 06-18-2019, 01:17 PM
Received 19,186 Likes on 13,910 Posts
'20-'21-'22-'23-'24
First I’ve heard of it called Ice Mode also. But then again, I’ve never had my ABS come on that I know of.
Old 06-18-2019, 01:18 PM
savage
savage's Avatar
hoosiers, everything else stock
To Has anyone been able to delete ice mode out of C7?
Old 06-18-2019, 01:22 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
What size Hoosiers?
Old 06-18-2019, 01:23 PM
savage
savage's Avatar
please google c7 ice mode , its a real problem driving c7 to the limit
Originally Posted by RichieRichZ06
What size Hoosiers?
315-30-18 up front and 345-35-18 rear on a 2016 zo6
i also see guys 305-30-19 square with same problem
Last edited by Steve Garrett; 06-18-2019 at 09:33 PM. Reason: Merged Posts - Please use the Multi Quote button to respond to multiple people in a single response.
Old 06-18-2019, 01:41 PM
Walt White Coupe
Walt White Coupe's Avatar
Received 2,221 Likes on 1,139 Posts
I don't see any video on your facebook page.
Quick Reply: Has anyone been able to delete ice mode out of C7?
