radiator leak
radiator leak
hey fellas I have had my 08 C6 for about 4 months and now that its starting to warm up here in North Texas I seem to have developed a mysterious leak? it comes from the front drivers side but when I have checked I cant seem to trace it, anyway it does not get hot while driving just after I have stopped seems to be a small puddle about the size of notebook any ideas to help me trouble shoot is appreciated.
If the C6 radiator is the same as the C5 (which it probably is) it's probably leaking from the plastic tank on one side or the other if it is actually the radiator. You can also check the coolant reservoir as these tend to develop leaks, or the water pump itself. I have seen leaks from both the radiator and the coolant tank.
rc51racer (09-24-2019)
Race Car Tech
I had a leak that took me awhile to find. I could see the coolant, but not where it was originating from. I did a 12 hour cold pressure test and finally saw the small seepage coming from behind the water pump pulley. It was the water pump seal leaking.
I was not overheating, and very minimal coolant loss as well.
As the seal leak got worse, I started to see coolant on the belts, but only some of the time, I guess depending upon where the water pump shaft stopped when parked.
I replaced the pump, and no issues since. That was approx 60K miles ago
Received 1,789 Likes
By the way, don't forget to spit it out.
Good luck.
thanks or the replies fellas but took it to a friends muffler shop to day to get a look see underneath seems to a have a small pinhole leak at most some im gonna try the coolant tablets first then replace the radiator if it persist which the leak seems to come from the plastic part underneath also yes its antifreeze not the AC
Former Vendor
DeWitts...and make sure you do not have dissimilar metals in the cooling circuit, as it will set up galvanic corrosion creating pin hole leaks in all that expensive aluminum.
P.S. heed post 11...
well the tablets were suppose to just be a band aid or temp fix but it actually worked anyway now I have a mysterious radiator fluid leak now I have to check the reservoir everyday and its low but no leaks anywhere? now I have seen some splash residue in front of the reservoir but no leak I stumped oh and the car never overheats it does get to about 235 but will drop back down to 185-190 once I get driving
