If a C8 Corvette is a mid-engined car, how is a C4 not?
Seriously, seeing how the front of the engine/transmission assembly of a C4 is basically flush with centerline of the front wheels, and the rear face of the C8 engine/transaxle is basically flush with the centerline of the rear wheels, aside from the convention that mid-engined means motor behind and not in front of you, how is a C4 not considered a mid-engined car?
Recently, I had my '96 get a little slide-ways under braking at a surprise stop sign hidden at the end of a tight turn. The back end didn't come out so much as my car pivoted (gently) around an imaginary point over my lap. It was the weirdest thing. It sure didn't feel like any other rear wheel drive vehicle I had get a little loose on me. 😆
My two cents. The C4 has the engine and transmission mounted in front. The C5, C6, and C7 have the engine in front and the transmission in the rear for better weight distribution. Both have everything between the axles. However, it's all sort of spread out. In the C8, and other "mid engine" cars, they crammed everything as close to the center of the car as possible, so the engine is actually more in the middle so . . . mid engine.
Antarctico (07-23-2019)
Technically, the cutoff is of the majority of the weight is over one of the axles. So the c4 through c7 are front mid, and the c8 will be rear mid.
That said, most performance cars have adopted this strategy. Its pretty typical.
Rear mid cars are MUCH more twitchy. With a front midengine, you can get 20, 30 degrees of rotation and still get the car back in most cases. Rear mid, it's a LOT less. I expect to see a lot of the old guys who buy the C8 putting them into ditches, curbs, walls, etc.
The following 3 users liked this post by FAUEE:
Received 1,401 Likes
C4 is front mid technically. C5 is front rear mid because of the trans location technically... it gets muddied. Late C4 to C5 the weight distribution is about the same but having the saddle tanks on the C5 keeps the rear from being twitchy, plus fuel level doesnt effect performance as much because the tanks are around the middle moment of rotation of the car.
The following 5 users liked this post by RIC96:
bac22 (07-25-2019),
ErrrrCar205 (07-25-2019),
helives4u2 (07-23-2019),
lotsofspareparts (07-23-2019),
LWesthaver (07-24-2019)
I dunno... the c8 has a pretty large golf club storage compartment...
+ the fronk!
+ the fronk!
Here how I think this subject should be addressed:
Years ago, when I first joined this forum, some topic came up where I pointed out the C4 was front-heavy. Might have had something to do with "guest drivers" throwing the rear so easily when driving my car. IDK. The point is I was quickly challenged. IIRC, they corrected me -- pointing out the weight ratio is: what? 48:52 IIRC. Even if that's wrong, it's close. So the question is this....
Since prior generations of Corvettes were already nearing the 50:50 equilibrium point AND since so many have been opposed to converting a Vette to rear engine, fewer cylinders, and whatever else, why shouldn't the first thought be...what are they really getting from the conversion? Obviously, the VW set a trend in snow performance having the engine in the back but we aren't talking snow. And, I didn't think having more weight in the rear was an advantage on the track (or even in town). So, is the conclusion that "It's pretty typical to adopt this strategy" as much about chasing the Joneses?
Was I jumped on too quickly years ago? Why wouldn't having more weight in the rear help with acceleration during cornering? Obviously, I could Google this but I'm guessing it's really the thought behind this thread?
Moving the engine behind the driver put more weight over the rear. It allows for better launches and getting on the throttle earlier and harder exiting corners. Also rotates better in the corner. No amount of computer controls could do that. That said, GMs stability controls, when used, will keep novice drivers out of ditches and tame the inherent twitchiness of the true mid engine design. Tad himself said with the ZR1 the C7 reached the pinnacle of what they could achieve with the FME layout.
Antarctico (07-25-2019)
Show me cars the zr1 isnt beating..
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
I think you might be reading too much into the question! To rephrase your point, I like to think my C4 is still relatively advanced, for a 30-year-old platform, in comparison to modern cars. Plus we do have the new C8 beaten in one important performance category: Grocery capacity! 😆
With that little load, you must be a skinny fella!
Just a guess but but it must have something to do with when I’m sitting in the drivers seat of a C4 and the hood open I can basically see the whole engine right in FRONT of me whereas in the C8 you see nothing but the FRUNK
Well they’re pretty much equal apparently “The combination of the frunk and the trunk make up a total of 13 cubic feet of storage space, says Chevy”
I believe a C4 coupe is also 13 cu ft however you can’t obstruct your view storing in a C8 like you can in a C4 so I’m betting you can store more in a C8 and still safely drive also a C8 definitely has more cargo area than a C4 Vert
