C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
Upgrade Your HeadLights and Taillights! Aventador Style
Old Jan 7, 2020 | 01:05 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Default Upgrade Your HeadLights and Taillights! Aventador Style
Hey Guys,
Introducing to you to the Morimoto XB LED Headlights and Taillights.
Please contact us for information and pricing!
PRODUCT DETAILS
NO SUBSTITUTES: Yeah the HID headlights that came on the C7 Vette's perform well enough, but as the saying go: stock sucks! Upgrade your setup to a full LED setup with Morimoto! Thankfully the new Morimoto XB LED headlights: Look great. Are well-built. Have a virtually infinite life span. An unbeatable warranty, and out-perform the alternatives. They are the first and last aftermarket option that the C7 Corvette Community needs, because when it comes to headlights: there is nowhere else to upgrade from here.
PERFORMANCE: We've always been blown away by the fact that even though the C6 came from the factory with OEM HID headlights, the performance was sub-par. The low quality optics inside the lights were not only poorly designed to begin with, but often lose 50% or more of their intensity over time due to de-lamination of the reflector bowl inside - leaving you with next to no light output to illuminate the road. The good news is that Morimoto's 2014-2019 Corvette headlights produce a well defined beam pattern with a great amount of width, intensity, and a proper distribution of light that will far out-perform the stock setup.
DOT APPROVED: Make no mistake, these will produce a much different [better] result than slapping some LED replacement bulbs into your stock housings. Their projector optics meet & exceed all SAE, DOT, and FMVSS108 regulations when aimed properly...and that's easy to do with their integrated vertical/lateral adjusters.
PLUG-N-PLAY: Wiring is easy too! This LED projector headlight kit is designed to work on your C6 Vette without any modifications. They will plug into the factory connectors for the stock headlights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No error codes, no flickering, hyper-flashing, or radio interference. They can easily be removed, and will not void your factory warranty.
SEQUENTIAL LED DRL: Game Changer! Their LED daytime running light is powered by Osram 5000K LEDs and is insanely bright, easily visible during the day. They have a fully sequential LED turn signal behind modern "3D" type optics on the outside edge of the headlight too.
WELL-BUILT: Their UV-coated polycarbonate lens will resist the test of time, ensuring your Vette's new headlights will look good as new for many years to come. The PPS plastic housing is light-weight and much stronger than comparable alternatives. The die-cast aluminum heat-sinks inside the housings provide more than an adequate amount of cooling for the OEM grade Osram LED chips that produce the light. These complete headlights may be new to the market, but Morimoto's XB LED fog lights have proven themselves perfect after 5+ years out now, which is confidence inspiring.
THEY LOOK: Amazing. At least in our opinion! The subtle elements incorporated in their design are more than enough to make them stand out, but they're clean enough to be considered top of the line original equipment to those who don't know any better.
PREFER VIDEOS?: Check out
overviewing these lights!
PRODUCT DETAILS
STOCK SUCKS: No doubt the C7 Vette is a badass design - but if you've already upped the ante by making more power, new wheels, and fatter tires, then it's time to ditch the stock lighting setup too. Morimoto's unbeatable XB LED fog lights have been top sellers in our catalog forever, and we couldn't be more excited to see the lineup expand with offerings such as the new high-performance XB LED tail lights too!
COMPATIBLE: With all C7 Vettes from 2014-2019, these complete Chevrolet LED tail light assemblies will swap directly in place of the original C7 Corvette tail lights, use all of the stock mounting points, and should not take more than 30 minutes to install the pair.
PLUG N PLAY: Wiring is easy too! The XB LED tails are designed to work without any special wiring. These C7 Corvette tail lights will plug into the factory connectors for the stock lights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No additional resistors, modules, etc needed!
STYLE: These Chevrolet LED tail lights don't look out of place on the Vette either. While their styling is far more modern than the old incandescent tail lights - they're not going to awkwardly turn your Vette into a spaceship either! We love the way they look and think they'd be a welcome upgrade to the rear end of any C7 Corvette.
WELL-BUILT: These C7 Corvette tail lights’ durable polycarbonate lens will resist the test of time, keeping the housings looking new for many years to come. The injection molded ABS housing is light-weight and much stronger than comparable cheap alternatives. The XB Tail lights may not be the cheapest new Chevrolet LED tail lights for your Corvette, but they're OE quality, and as the saying goes, you pay for what you get. Although the tails are new, we've sold many thousands of the XB Fog lights and to date, have only seen a small handful with problems...no joke.
Old Jan 8, 2020 | 01:39 PM
MerakiAutoworks
Supporting Vendor
Contact us for pricing!
Text: 213 394 2886
Email: Info@MerakiAutoworks.com
-Josh
Old Jan 9, 2020 | 02:28 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 10, 2020 | 11:54 AM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 11, 2020 | 01:45 PM
MerakiAutoworks
Supporting Vendor
Contact us for Pricing!
Text: 213 394 2886
-Josh
Old Jan 12, 2020 | 02:10 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 13, 2020 | 01:23 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 14, 2020 | 01:18 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 15, 2020 | 04:14 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 16, 2020 | 12:09 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 17, 2020 | 02:41 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 18, 2020 | 01:33 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 19, 2020 | 01:42 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 20, 2020 | 02:20 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 21, 2020 | 09:39 AM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 22, 2020 | 08:43 AM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 23, 2020 | 08:53 AM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
To Upgrade Your HeadLights and Taillights! Aventador Style
Old Jan 24, 2020 | 08:55 AM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 25, 2020 | 01:29 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
Old Jan 26, 2020 | 03:40 PM
MerakiAutoworks
Supporting Vendor
Text: 213 394 2886
-Josh
