Active Handling kicks on in low speed turns
Also sounds to me like a wheel speed sensor. Though may be steering angle sensor?
I don't know how it is on the C5, but on Audis there is a diagnostic tool I can use to watch reported wheel speeds in real time. In the past I used this to determine the problem corner (turned out to be a broken tone ring).
issue. Slow turns in a parking lot or at a stop sign will trigger the active handling same as you. I think it has something to do with the steering wheel position and yaw rate sensor. The car is turning more than the steering thinks it turning and it think you’re out of control. I haven’t replaced the steering wheel sensor yet cause I’m dreading the job. Did you ever figure out what happened?
When the measured yaw rate isn't what the system expects for your speed and steering wheel angle, it assumes you're understeering or oversteering, and the Active Handling system kicks in to correct that problem.
Both of the mods listed above cause the car to yaw faster than the system expects, for a given steering wheel angle. I mean that's the entire reason you installed them, right?
So of course the Active Handling system interprets the increased yaw rate as oversteer, so of course it tries to correct that (non-existent) oversteer.
There's a thread somewhere on the forum where somebody is working on SWPS signal processor, which (if/when it is completed) will allow you to fudge the SWPS signal to be what the AH system expects. The theory is pretty straightforward, but the SWPS signal is a little weird, so it's not a trivial project. But it seems do-able. Some searching should hopefully find the thread.
