A simple and inexpensive convertible torsion strap fix
I went to a local industrial supply hardware store and bought some 5/32" bungee cord material along with some 3/8" hog rings. It cost me a couple of bucks. I also got a few #6 5/8" long screws to replace the very short screws that anchored the lower part of the torsion strap . I made new straps as shown in the pics and used the #6 screws to install them and they work great! The longer screws made it much easier to install the replacement torsion straps. Once you secure the bottom anchor using the #6 screw, then you simply stretch the homemade torsion strap over the head of the original pop rivet head (as seen in the pic) and you are done. The torsion strap is always under tension in the up or down position so it will not come off the pop rivet head.
First, I made new torsion straps with two strands of 5/32" bungee between the loops and they were about 3-3/4" long. They did not have the pull necessary to move the rear window out of the way of the tonneau cover. For my second try, I made new straps that has 3 strands of the 5/32" bungee cord between the loops and the overall length of the strap is 3-1/4" as seen in the pic. I used hog ring pliers to compress the 3/8" hog ring over the bungee cord and then used regular pliers and my vise to put the squeeze on the hog ring to flatten it out and to hold everything in place.
To install them. first I secured the lower anchor of the new torsion strap using the #6 screw and a 1/4" nut driver. Then I stretched the torsion strap and pulled the loop at the top end of the strap over the original pop rivet head and that's it. It literally takes a couple of minutes to install them. The tonneau cover clears the window by over 1/2" now.
The hog rings don't come in contact with the convertible top. They are below the ribs that support the top. Just in case, I took off any sharp edges with a sander before I installed them. The new torsion straps do not cause any humps in the convertible top when it is down...it is smooth. A simple and easy solution to this common problem...I will see how they hold up over the long run but I think they may work out well.
This is a great Forum!
You mention going to a local industrial supply hardware store for the 5/16 bungee, what was the store?
You just reused the head of the rivet, were you able to just cut the old strap away from the rivet without actually drilling or removing the rivet?
If you were to do this repair again would you change how you did anything? (I don't have hog ring pliers but I think they are cheap?)
Thank you, I have to get this fixed over the winter it's driving me crazy!
I cut the old strap away from the rivet head (or they just fell off because they were in very bad condition). Just be sure to pay attention to the overall length and use 3 strands of bungee between the hog rings (just like I mentioned in the previous post). If the strap is too long, it won't work. 3 strands gives it the strength to pull the top away from the tonneau cover.
I made the straps 3-1/4" long, but I might make them 3" long if I were to make them again.
It looks like the bungee was actually 5/32" and not 5/16".
