OldCarBum's '73 Restomod Project
I'm still working full time, so getting started, I'll only have a few hours a week to devote to the build.
I am the third owner of my '73 which came from the factory white with dark saddle interior.
The original owner did a repaint and changed the interior to black 20 + years ago.
It has been a California only car that was well taken care of, is rust free, at least in all the areas I can see, and is pretty much all original except for some replacement items like the carburetor, ignition, brake calipers and radiator.
Almost every part and component on it will be replaced with new or the original parts will be completely rebuilt or modified before being put back on the car.
Any parts coming off the car will be offered for sale in the C3 Parts For Sale Section.
Upon the completion of my project it will retain it's all original appearance going down the road or looking into the window, however if you look under the hood or crawl under it, it will be a completely different story.
Here are a few photos of what I'm starting with.
Popular Reply
It’s amazing how a coat of primer and powder coating can make my non professional welds appear professional.
Per the recommendation of my painter I had it powder coated 60% gloss.
Afterwards, I pulled some of the suspension boxes down and opened up my new G Force crossmember.
Tomorrow I’ll do the fit check, buy the new mounting hardware and get the first piece installed on the frame.
If my car looked 1/2 as good as yours already does, I would not have touched mine (besides the mechanical issues).
Im certain yours will be a top-notch resto and most of all….PICS!! 😎
I will be watching the FS section for your parts! Lord knows my 74 needs’em! Lol
Greg
I highly recommend you replace that front rubber bumper with a solid, heavy NON-FLEX fiberglass bumper. The Trueflex stuff gets alot of recommendations, but I found that it took just as much bodywork, and ultimately, the structural integrity, and rigidity of the Truflex is not as solid as the rest of the car body......and ultimately, in the sun, I get waves, and distortions that detract from the car. I would go a step further to say that its worth laying another layer of fiberglass on the in side of the NON-flex fiberglass bumper to ensure its solid and rigid. They will ALL need bodywork to match the body lines, whether its Trueflex or the traditional NON Flex fiberglass.....so you may as well accept that and realize it will take work to get a good fit.. Don't compromise with something that after the paint is dry you regret it.
It hasn't been dyno tuned yet, but we are hoping to see 600+ hp.
It isn’t much but it was all I had time for.
The trim rings are aftermarket, good ones in near perfect condition.
I believe the center caps could be all original to the car.
All will be listed in the C3 parts for sale section.
Before I started I measured from the ground to the fender lip to see how much the measurement would increase once the spare and tub were removed.
I was amazed to see that the rear of the car only raised 1/4”.
I won’t be using the original spare tire rally wheel so it will be listed in the Parts For Sale section.
Since then I’ve found I really like the cleaner lines of the 73’s front end and the lines of the 68-73 rear.
I decided I’m either going to remove or paint the rear bumpers black to match the body to get the balance I’m looking for.
I decided I’m either going to remover or paint the rear bumpers black to match the body to get the balance I’m looking for.
