68 HotWheels vette gets some minor upgrades
https://www.summitracing.com/parts/cca-11-106-3
My latest issue is parts availability for a spring build. The Brodix heads keep getting the delivery date moved back, not that I have the cash for them at the moment but buying them and getting them should coincide. These are what Im building around, but I may end up with AFRs which would bump up the compression unless I add more quench to bring it down. Im hoping I dont as that would have to be a big quench area. At that point I wouuld adjust to get 11:1 and use an octane booster
https://www.summitracing.com/parts/bro-2061000
https://www.summitracing.com/parts/afr-3610-1
For anyone not familiar with the car its this one
one of the reasons the 327 didnt last
the 396 block when it go t rebuilt last winter
THis is where we sat as of last fall. THere was a minor mishap while the driveway was being plowed last mointh with the plow truck bouncing off the wall due to brake failure which knocked a lot of things off the shelfs and off the nose of the car. A few dings and some scratching but no one was hurt so we are moving on form that unfortunate event. I got worse scrpas at a car show last year which actually did **** me off.
This is where we sit as of last night. THe seats are out, the carbs are at Holley and I have a small list opf things we need to do.
I removed the tin from below the antennae last year and added ground directly to the power antennae that was installed. Seems the tin is needed to reflect the radio waves back to the antennae to help with weak strations. HI go that info from one of the engineers at my job. Good to know.
SO Im going to cut and bend a new one.
The rebuild of the 5 speed netted a improper size drive gear so I cant get the speedo to work so I bought a GPS to mechanical drive adapter/ convertor from Jegs. THatt needs wiring and install
I broke 3 or 4 tach drive cables last year so we are converting to electronic and ditchhing the tach drive. I may just plug the MSD tach drive or buy a new on tacjh drive dizzy. I saw one used in NH so that may come my way.
obviously the carbs need to be reinstalled but that is going to wait until we have a definitive resolution on when the 427 is going to getr rebuilt and installed. Another temporary solution is getting a valve job on a set of cast iron heads for the 396 and employing that for the spring and then doing the swap once the 427 is build and broken in. That is a wait and see.
Im needing new rubber so I may go back to a set of 15 inch turbines to see what they look like. I have those and they need polish paint and clear coat. If I dont like them I will be getting a chrome set of 17 or 18 inch wheels eventually but I hate these polished aluminum ones, Just way to much work with brake dust and keeping them shiny
semi open combustion chamber at 110 cc. I have closed chambers in there now. The pistons in there are a very small dome so these should fit and keep the compression in the 10:1 area still
Popular Reply
The lifters are obviously THE most important part in that whole setup as that destroyed everything except the block, pistons and connecting rods. Everything else got eaten buy either the lifter or the contamination in the oil.
On my project the good news is i still had the tin plate in under antenna, bad news is my reception still sucked so im putting in a bigger piece and improving the grounds
So yesterday I cut the tin for the antenna reflector, then I got the seats out, the steering wheel out, and the passenger dash pad. Today I got the center gauges out and started to get that rats nest sorted out. When I was swapping the EFI in then out again I had to remove some of the old wiring and just never "purtied it up". IT starting to look a lot more presentable.
the tin I had for the antenna
after copying the tin over to card board, test fitting, trimming to fit and using as much of the tin as possible
punching the hole for the antenna
added the silicone to keep it from rattling, square tab is to attach the ground, still wasnt dry, when it does I will add some rust prevention and install
after getting the passenger pad off and seeing that rats nest
cleaning it up, more to do after work this week. Getting better slowly
I was checking out the machine shop you use. Looks like they build some sweet stuff. I've been looking for a shop to build a 455 I have laying around. I'll look into them!
saturday morning. So I took apart one of the remaining solid roller lifters and they use a tiny retiner ring to hold the axle in . The wheel uses needle bearings. My theory is the retainer failed an dthe pin walked out releasing the bearings to get chewed up as well as the lifter itself disintegrating. Just a bad design. THey were mad to be rebuilt and that is the flaw. THey should be a press fir and use bushings.
this is one of the survivingg roller lifters with the retainer removed and i knocked the pin out a bit, that is one of the needle bearings I found in the pan
the lifter disassembled
Back to the car, so after work each night I tried to get a few minutes in cleaning up my wiring under the dash this week. not any pics of that yet. I will grab some when I got out there this morning. But I did get the center carb inthe mail and took it apart for inspection and gasket up grades......
my new baby...pristine shape and beautiful
the gaskets put up an incredible fight, they would have never leaked but then I wouldnt be able to get to the jets or the power valve
THis gasket was a long fight. I have the non stick blue ones to replace these so I can tune the carb
the fuel holes are tiny but there is 4. Different design then the new stuff
never saw a gasket in here before
I wanted to replace the accelerator pump as well to be sure its alcohol proof. I have some newer pumps but I may just put in my 50 cc pump from my frankencarb to improve the squirt to eliminate any bog with my driving habits. Its too bad they didnt include pumps on the outer carbs
THe old school check valve
Just one of the end carbs disassembled to check them out. I wont change anything in these just yet. I believe the cork will be fine with ethanol and there isnt much more to these carbs.
If I do end up being lean at WOT I have the AED plates tp replace these that utilize jets
I will finish cleaning my intake and mock these up to oogle them. I just love staring at these when they are set up. My weekend goal is to get the wiring cleaned up, I need to make a bigger plate to hold the electronics or make a second one for the GPS and pull th etach and put in the electronic conversion....updates to follow
