FS: 59 Tach Drive Generator Fresh Rebuild
This is the generator that came with my 59 Corvette when I purchased it in 1973. The car was disassembled when I got it. I don't know if the generator was ever rebuilt or replaced prior to my ownership. I just had it professionally rebuilt locally. It may fit other cars and years too. I don't know much about these units. It does not have the Delco tag, but I have seen them on line at Corvette Central and Zip Corvette, $15 to $25. https://www.corvettecentral.com/c1-5...f%3fcount%3d61 I also have the original mounting bracket and Generator tension adjuster. PM me with any questions or concerns.
I am not the expert on these units so please do your homework.
********** Everything $675 or make offer ***********
PS:
I can take the brackets out of the deal to help with the price if needed. PM me if you have any knowledge of what I have here. I am not an expert on this item (generator).
I know it was in use on my 59.
The brackets came with my 59.
New tag came with brush set
grommets appear to be original
used, oem, still has some original paint
PS:
The brackets are right off my 59. They are original.
Rich says this is for a Chevy with a power steering pump. But I have been told it will work on a C1 for the tach. I am not sure at this point.
Make offer.
Make offer.
Yes, it'll work fine. The designers likely had a clearance spec, generator to the hood, that they had to follow. Just 1/4" lower, but it required different end frames.
I had a Pass car generator as a spare for my '59. It had provisions for the tach drive, same as the power steering setup.
Just so you know, what are the dimensions from center of shafts to the center of the mounts. They should be the same.
1112043 Corvette frames - 3 1/4"
Pass car W/PS - 3 1/2"
Rich
Rich
Rich
Rich
