Are my wheels on the wrong way??
Old Apr 12, 2023 | 04:15 PM
anyways's Avatar
anyways
Cruising
Default Are my wheels on the wrong way??
Ok so. 88 with 94 wheels I believe.
edit: sorry garbage angle, car is in storage this is all I have for my mounted wheels
When they were installing them the guys INSISTED it was the correct way before he put them on and explained how the teeth should be facing forward etc. almost every other thread and pic when I search 94 corvette has them the other way. What is right!!??
Old Apr 12, 2023 | 04:19 PM
WVZR-1's Avatar
WVZR-1
It might have been better to have posted a better snapshot BUT if all 4 seem to be incorrect/orientated differently than you normally see just pick one and remove it. If the back-side is marked for a location that isn't correct then you could 'assume' then that all aren't correctly mounted. Mounted as they are now are all 4 of yours orientated in the same direction?
This is a correct left side wheel? If the wheels are actually from a '93+ then there could also be a mix of incorrect 17 X 8.5 and/or 17 X 9.5. Need rotation confirmed and widths done to match 4 X 8.5 or 4 x 9.5 OR maybe 2 X 8.5 and 2 X 9.5 with 8.5 to the front and 9.5 to the rear.
https://www.ebay.com/itm/14503269536...3ABFBMpIaG8u5h
Old Apr 12, 2023 | 04:20 PM
mothman52's Avatar
mothman52
Pretty sure the wheels are notated on the inside as to which side of the car they're supposed to be mounted. I suppose it could be a personal choice, but which way do you think they look better?
I've got a similar situation: My rear driver's side wheel is meant to go on the other side, so the cutouts face a different direction than the fronts do.
Old Apr 12, 2023 | 04:48 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
It's a little difficult from that angle however for all "sawblade" wheels that came on 91 - 95 base model C4s the correct orientation is like this:
That being said the wheels that came stock on an 88 were of a unique design (as were the ones on 89 & 90) and they DID face the opposite way of what I am showing you.
Old Apr 12, 2023 | 04:50 PM
Wayne88's Avatar
Wayne88
Here's my '88, with probably the same wheels as yours.
I'm positive these wheels are on correct.
Old Apr 12, 2023 | 06:14 PM
anyways's Avatar
anyways
Cruising
wow thank you all for the quick responses!
I guess ill take my wheels off and check the inside. Im sure theyre wrong though, i guess ill have to get the tires remounted and stuff smh
Old Apr 12, 2023 | 06:21 PM
WVZR-1's Avatar
WVZR-1
The thought on ties is 'only' if they're 'directional'. Many might just check tire date codes and if they're very old replace or maybe run as mounted for a while longer and shop for tires. Check tire date codes the same time you pull wheels to check.
Old Apr 12, 2023 | 06:50 PM
anyways's Avatar
anyways
Cruising
Tires are brand new - just bought them. They are directional unfortunately - Firestone Indy 500.
Old Apr 12, 2023 | 07:00 PM
Zealot's Avatar
Zealot
Veteran: Marine Corps
If you just bought them, take them back and have them mounted correctly.
anyways's Avatar
anyways
Cruising
Nevermind im dumb, they are asymmetrical but not directional. Phew. easier work then
Old Apr 12, 2023 | 07:04 PM
WVZR-1's Avatar
WVZR-1
Did you buy 'local' - it's a bit odd but not unheard of that a tech wouldn't pick up on the mounting on the wheel 'back-side'. Were the wheels put on to the same positions that the old were? It might be worth a conversation 'after' you confirm what's actually there and where they need to be. A responsible 'local' merchant I'd think be inclined to help. Was there a national chain involved with the purchase and arranging mounting?
Old Apr 12, 2023 | 07:11 PM
anyways's Avatar
anyways
Cruising
I had the 88 stock wheels on my car, bought the 94 wheels and had them refinished - the same shop that refinished the wheels procured me the tires.
After the fact, I took the new wheels to the car shop that was working on my car and they swapped them out, so seems its the shops fault but thats an easy fix now that I know they are in fact NOT directional.
Old Apr 12, 2023 | 07:16 PM
Blue Bucket List's Avatar
Blue Bucket List
If they give you any grief about swapping them around have them pull one off and look at the back side and I think the discussion will go in your favor from there. Sawblades are clearly marked on the back side which side they go on.
Old Apr 12, 2023 | 07:25 PM
ThomasR's Avatar
ThomasR
The wheels are backwards.
Old Apr 12, 2023 | 09:43 PM
vetteLT193's Avatar
vetteLT193
The tech probably was confused because early C4's were like this, leaning forward on top. But for 94, leaning back on top.
I kinda like the newer wheels mounted backwards on the 1984-1990 cars, it seems to fit better to my eye
Old Apr 12, 2023 | 10:34 PM
topfuel67's Avatar
topfuel67
The cover of the FSM shows the correct direction for each year as well. My 92 FSM shows the wheels the same as the pictures above.
Old Apr 13, 2023 | 07:06 AM
Incorvettei's Avatar
Incorvettei
I agree. The wheels are on incorrectly
To Are my wheels on the wrong way??
Old Apr 13, 2023 | 08:04 AM
mazdaverx7's Avatar
mazdaverx7
If you remove the wheels, the side of the car they are supposed to be installed on will be cast into the wheel. It will either say left or right. Hopefully that will help. Note that the front and rear wheel width is different.
Old Apr 13, 2023 | 09:43 AM
LT-1 kid's Avatar
LT-1 kid
if your asking a question about your wheels maybe you should take a better picture so we can see the wheels
Old Apr 13, 2023 | 01:34 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
The guy absolutely put them on wrong. I'd take it back to the tire shop, and ask them to pull one off. Here's what you're looking for:
