Slightly bumpy ride after single tire replacement
Replaced single tire due to flat at Discount Tire.
Car drives slightly bumpier than before. Steering wheel does not shake. Have only driven up to 40mph.
Thought I could be imagining it, but someone else also drove the car only 50 feet and unprompted asked me if something was wrong with the new tire.
Brought the car back into Discount Tire and they said balance/tire was fine, the wheel has a slight bend that could be the cause.
These are the 'facts':
1. Should I remove the balance weights and see how it drives (and put them back on or bring back to shop if it drives worse)?
2. Get a new wheel and see if that fixes the problem?
3. Rotate rear wheels and see if I notice a still bumpy but different ride?
4. Replace the right-rear tire too?
5. Something else?
- Prior to replacing the wheel, I did not notice any issues
- Drove 50 miles home on it in middle of night after a flat tire. Then another 5 miles to Discount Tire 2 days later.
- Discount tire guy says driving on the run flat would not have caused wheel damage if there were no potholes encountered (i was driving on 'good' roads)
- Replaced single tire -- Driver Rear tire with OEM (summer) tire. New tire has 9/32" tread. Other 3 tires have 9800 mile & 6/32" tread
- Discount Tire guy says tread difference should not perceptibly cause a ride difference
- Wheel on replaced tire now has 11 1/4ounce weights. Before it had no weights (none of the other tires have weights)
5. Something else?
Received 1,395 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
I missed that you said the wheel was bent. That is your problem, have it straightened or if possible replace it.
The following 2 users liked this post by BearZ06:
CaptainFester (05-01-2024),
proeagles (04-30-2023)
Repair the bent wheel (wheel repair is cheap), and always replace tires in matching axle pairs. Imagine walking around in shoes with one thick sole and the other thin.
The following 5 users liked this post by Kracka:
Devereaux (05-01-2024),
itsonlyairandfuel (05-01-2024),
MikeinAZ (05-01-2024),
NorthernProducer (04-30-2023),
tadda (04-29-2023)
The following 3 users liked this post by BillBall:
Does discount tire agree there is a problem? What do the advise? Why is the wheel bent? Ive never dealt with them. But they are supposed to be good. They should figure out the problem.
I would not want a bent wheel.
Received 6,996 Likes
The following 2 users liked this post by tadda:
C8Rob (05-01-2024),
My guess is it happened with the flat tire. Or, you're just much more cognizant and aware now that you had an issue and repair work done.
Received 19,536 Likes
'20-'21-'22-'23-'24
I agree with getting the wheel repaired for the bend (or replace it if needed) and see how the car performs.
Discount Tire (04-30-2024)
The bent rim certainly could be the issue, but i’d recheck things, especially the balancing weights, after you have made corrections. My personal experience is that shops vary one from another. Go to a Discount Tire where they deal with high performance tires and you will get a good dynamic balancing. Don’t and you might not.
re-clocking the tire on the rim might reduce the amount of corrective balance weight.
I totally agree. The tires on Vettes don’t require more than one or two weights. That is the first clue there is a problem.
2.75oz really isn't too concerning on a tire/wheel assembly that is as heavy as the vettes rear wheel. 1% rule for max balance weight, the rear wheel is big and the Michelin ZP tire is crazy heavy.
Acpantera (05-01-2024)
Even so, that's a lot more weights than I've even seen on C8.
This is not the Corvette ownership experience we strive for. Our team would like the opportunity to learn more about the tire on your C8 and investigate ways we can potentially assist. When you get the chance, please send an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.
