Question - Tire Size For 20/21 Wheels On a GS or Z06
Old May 17, 2023 | 08:29 PM
Bob-G's Avatar
Bob-G
Default Question - Tire Size For 20/21 Wheels On a GS or Z06
For those running 20/21 wheels on a wide body, what tire size and brand are you running that does not rub? Thanks in advance.
Old May 18, 2023 | 02:38 PM
Bob-G's Avatar
Bob-G
Thank you.
Old May 21, 2023 | 02:27 PM
Obe1 GS's Avatar
Obe1 GS
You didn't state the width of the rims; the stock rears at 12" wide. A 295 rear width is much narrower that the stock 335 width tire.
Old May 22, 2023 | 10:40 AM
Bob-G's Avatar
Bob-G
Discount Tire, if I went from 19/20 to 20/21 using the same width on the new wheels;
- what is the widest tire I could put on the rear without rubbing or causing any issues? Would it be 325/25/21?
- would the 285/25/20 still be the size of choice for the front using stock width, again, without rubbing or causing any issues?
- I am thinking about moving from the OEM tires to the all season run flats in the "21" size because I am hearing the ride is better, and they are quieter. Since you know the tires, is that accurate (ride better and quieter)?
Thanks in advance for your info and assistance.
Old Jul 5, 2023 | 12:56 PM
Little Red Corvette1's Avatar
2016 C7 of the Year Finalist
Default Z06 Tire Selection
I would like to know this also.
Old May 20, 2026 | 04:35 AM
Pegieton's Avatar
Pegieton
@Bob-G What did you end up using? Any pics?
Old Yesterday | 12:00 AM
gordoni's Avatar
gordoni
Just FYI, I run the 20/21 combo on a non-widebody. My rear wheel is 11" wide and I run 295/25s. That's probably as narrow as I would go on that wheel, so I'm not sure that's going to fit well on a 12" rim. Just something to ponder.
To Question - Tire Size For 20/21 Wheels On a GS or Z06
