[C2] Water Pump Belt
Old Jan 13, 2024 | 05:43 PM
sgorman3's Avatar
sgorman3
Default Water Pump Belt
I'm trying to install the belt that goes from the water pump pulley to the crankshaft pulley on my non-AC '67 big block. I read on the forum where it was suggested to cut off the head of one of the bolts that threads into the water pump hub and use this stud as a guide to slide the pump pulley onto the hub. Apparently Quanta makes two versions of this belt...Part #B-084A (which they call the "long version") and Part #B-084B (which they call the "short version"). Frankly, I don't know when you'd use one over the other since, as far as I know, the pulley size and the distance between the centers of the crankshaft and waterpump is the same for all 427 engines. Anyway, I ended up buying both the belts. For the life of me I can't quite get the shorter belt to fit. I was able to get the longer belt on but there's about a 1/2" deflection on the belt. It's a little looser than I would have expected. So I guess my question is has anyone else ran into this? I'm very hesitant to try and force on the shorter belt as I don't want to take a chance on damaging the water pump bearings. Any advice would be appreciated.
Old Jan 13, 2024 | 06:16 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The longer one is for repro pulleys. Take a medium Phillips screwdriver and put the end though the pulley bolt hole and walk it into the w/p hub
Old Jan 13, 2024 | 06:25 PM
sgorman3's Avatar
sgorman3
So I should use the shorter belt?
Old Jan 13, 2024 | 06:26 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I replaced that belt on my '67 427 (i believe it was the original belt) a couple years ago. I found it easier to remove and use the crank pulley as the loose component rather than the upper water pump pulley. I couldn't get the water pump to not spin slightly given the tension of the belt while trying to get it on the pump shaft - which made aligning the bolts a challenge. The lower pulley doesn't need the same amount of angle to get it properly remounted and the crank won't spin on its own.
Old Jan 13, 2024 | 06:48 PM
sgorman3's Avatar
sgorman3
Old Jan 13, 2024 | 07:16 PM
Nowhere Man
if you have original pulleys
Old Jan 13, 2024 | 07:18 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
yes.
Old Jan 14, 2024 | 03:35 PM
sgorman3's Avatar
sgorman3
How do I know if my pulley is original or not? It does have a stamping on the face of the pulley which says 3906656 CV which I believe to be the correct stamping number. Did they make aftermarket pulleys that had this stamping?
Old Jan 14, 2024 | 05:32 PM
Nowhere Man
look for a small PR stamp for repro pulleys
Old Today | 07:57 AM
TokyoMark's Avatar
TokyoMark
Retired
I don't have a lot of experience but had the same issue. I made a couple of very short all threads and got one in, then walked the H2O pump pulley in place and installed the other one. From that point you can install two bolts, back out the all threads and install the remaining bolts. The all threads have to be short as if they are not short enough they will not come out as they will hit the fan clutch. Quanta sells two belts for this as one is slightly larger to help with this issue. I got the smaller one and installed using the above method. (1966 L72) Good luck, cheers. Mark
Old Today | 08:24 AM
rich5962's Avatar
rich5962
Mark I think you posted in the Related thread, not the one you wanted to..
https://www.corvetteforum.com/forums...-new-belt.html
Old Today | 08:55 AM
TokyoMark's Avatar
TokyoMark
Retired
[QUOTE=rich5962;1609640275]Mark I think you posted in the Related thread, not the one you wanted
Oops, thanks, using my I phone this morning and screwed it up. Thanks
To Water Pump Belt
