Those who replaced their headlight lenses hows it holding up??
Old Jan 27, 2024 | 08:49 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Those who replaced their headlight lenses hows it holding up??
did mine a few years ago and they look like total *** now, they only looked good for about 18 mos. Such a a pain in the *** but am going to have to redo them.
Old Jan 27, 2024 | 11:29 AM
4SUMERZ's Avatar
4SUMERZ
I replaced mine with the original ones that RLSebring had in 2014, and they still look great. I have put 70K miles on the car since the change.
The only thing I do with these is use Meguiar's Gold Class Premium Quik Detailer to clean and protect the lens.
Using anything like Window cleaner will make them go to crap, as the ammonia attacks the coating.
Robert L Sebring passed away on Dec 16, 2023 RIP
Old Jan 27, 2024 | 12:30 PM
racerx3317's Avatar
racerx3317
Which lens did you use?
Old Jan 27, 2024 | 01:24 PM
pewter99's Avatar
pewter99
I don't remember, I will be digging out receipts later when I get home. Thinking about just buying the Morimotos this time
Old Jan 27, 2024 | 01:44 PM
racerx3317's Avatar
racerx3317
I’ve heard about issues with glass cleaner on certain brands, I’m curious to know which lenses as I just bought a set of umnitza’s. RL seems to not be in business anymore.
Old Jan 28, 2024 | 12:43 AM
wjnjr's Avatar
wjnjr
I replaced my original lenses with Sebring's Mexican lenses way back in 2020. So far, so good, they still look like new. A great guy who basically invented the C6 headlight lens replacement business, hope he's still doing it.
Old Jan 28, 2024 | 10:55 AM
hearnold's Avatar
hearnold
1st Gear
Default ACANNII replacement headlights
Anyone use the ACANNII replacement headlights? They are a little more expensive than the Umnitza lens but would save the pain of removing the lens.
Old Jan 28, 2024 | 01:19 PM
racerx3317's Avatar
racerx3317
I don’t know of anyone that has tried Acannii’s but a couple people tried the Anzo’s. Fit was kinda crappy around the gasket area. I’d probably stay away from those too. You get what you pay for. Morimoto has a 5 year warranty. The others is something like 90 days.
Old Jan 28, 2024 | 11:37 PM
4SUMERZ's Avatar
4SUMERZ
Hopefully he is OK...I ordered 2 sets from him back in 2014, so I do have a spare set if I ever need to replace mine again.
Old Jan 29, 2024 | 06:30 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I seem to end up replacing mine every 2 years with some of the china specials... they don't hold up well. I've heard everyone say Sebring is the way to go... might try that next time.
Old Jan 29, 2024 | 09:26 AM
Ron Dittmer's Avatar
Ron Dittmer
I restored a Saturn Sky with disasterous lower lenses. I took them off the car, setup my polisher horizontally in a vise, setup cardboard to "catch the fling" and within minutes the two lower lenses were beautiful.
BEFORE
AFTER
Done in minutes USING THESE TOOLS
I assume the same could be done with C6 headlights. Just get them off the car to protect the body paint.
Old Jan 29, 2024 | 10:02 AM
dr_gallup's Avatar
dr_gallup
Polishing lenses removes the UV stabilizer layer and if you don't do anything to protect the lens they will haze again in half the time.
Old Jan 29, 2024 | 10:18 AM
Ron Dittmer
Old Jan 29, 2024 | 06:33 PM
KennyPowers's Avatar
KennyPowers
Any recommendations on UV? (I have 4 lenses to maintain)
Old Jan 29, 2024 | 06:44 PM
pewter99's Avatar
pewter99
can't find my receipt.....
Old Jan 29, 2024 | 09:40 PM
DrKrieger's Avatar
DrKrieger
I installed the Morimoto head lights on the Vette, however, I redid the lenses on our 2012 Genesis, and used the Cerekote kit, and they look brand new. I helped my grandson who just bought his first car (2013 GMC Acadia), and his lenses looked horrible (the Arizona sun is at fault), and they turned out beautiful....and look perfect!
Old Jan 29, 2024 | 10:08 PM
pewter99's Avatar
pewter99
yeah there is no saving these....I see Morimotos in my future. Taking apart the headlights is a pain in the *** and then the cost of new lenses I'm not doing it again
To Those who replaced their headlight lenses hows it holding up??
Old Jan 30, 2024 | 07:03 AM
racerx3317's Avatar
racerx3317
I got the unmitzas for 70 bucks. I’ve never done the job so I’m not jaded yet.
Old Jan 30, 2024 | 11:20 AM
KennyPowers
If you can work a hand drill and wetsand its a snap to burn through the oxidation.. BUT then what?
So far mine are decent but not quite what new/replacements should look
Im curious about the UV coating (after working them over with wetsand and compound) bet it would really make them clear
So many new products out there.. ill ask my paint shop guys what they think
(Wont consider the c7 look, no way.. those are sharp lines, c6 is round smooth lines, not happening)
Old Jan 30, 2024 | 01:29 PM
info@umnitza.com's Avatar
0info@umnitza.com
Supporting Vendor
If you guys are getting the lenses from us - we have many in stock - I recommend the clear film for much longer life with them. Our lenses were the only ones we tested with a DOT testing facility and found to be clearer and better than OEM.
However, the sun still damages everything it touches, so we recommend the clear film for added protection both against the sun and against little debris. The combination of the lenses and the clear film is unbeaten. Where even OE lenses will crack and craze due to exposure, ours will not if you apply the film. Our lenses also will not oxidize or fade if you don't apply the film, but it's that added layer of protection that generally works better.
Also, as a reminder, we didn't litter the lenses with a lot of text or lettering, it's subtle, so you know you got a good product without shouting it to everyone
