Euro to US tail light help
Old Mar 3, 2024 | 06:55 PM
BlackBeetle's Avatar
BlackBeetle
8th Gear
Default Euro to US tail light help
I'm now a proud owner of a C6 Corvette, my dream car! But I'm also the not-so-proud owner of a Euro C6 Corvette.
There are some differences made to the Euro 'Vettes, but the one I can't stand the most are the tail lights. For those who don't know, instead of having 2 + 2 tail lights that all work as brake lights and blinkers and looking all cool, we Euros have a very different setup. Our outer tail lights are divided into 3 parts, 1st part is brake light, 2nd is reflector and 3rd is blinker. The inner tail lights are ONLY for fog lights, so they're off 99% of the time.
What I'm looking for is a way to get US tail lights working for the Euro harness. I don't want to fiddle around with reprogramming the BCM or changing wire harness, I want to try and do it in a more simplistic way, if possible.
From my limited knowledge and imagination, I can easily see having normal "presence" lights + brake lights on all 4 tail lights, that'd just be splicing the wires to both sets. My worry here are the blinkers. I have no way how the blinkers would work with the EU harness.
Has anyone done this? Is there some hidden plug n' play adaptor I can use that connects from EU to US tail lights? My goal is doing this as cheaply as possible (the 'Vette was sadly a little over budget), and labour rate around me is cheap so that's not a real worry.
Also I'm aware of these awesome lights, but at over 500€ that's my last option due to high price
Thanks!
Old Mar 3, 2024 | 07:40 PM
madsonp's Avatar
madsonp
I suggest getting a hold of @Dano523 and see if he can help you out, he’s kinda the resident Vette expert on this forum.
Old Mar 4, 2024 | 02:54 AM
craigyboy's Avatar
craigyboy
just buy the infirai tail lights and then splice the wires so you get all 4 to work. Ive done the exact same thing on my friends EU Z06
Old Mar 4, 2024 | 03:33 PM
DrKrieger's Avatar
DrKrieger
my brother-in-law (France) had a C6 Vette and did the exact same thing to have US tail lights.....
Old Mar 4, 2024 | 03:49 PM
BlackBeetle
8th Gear
My problem with this is that they look very orange in the videos, I really dislike the tone. I love the almost cherry red of the US tail lights and that's my goal.
Or are the Infirai not as orange as they appear?
Old Sep 4, 2025 | 07:11 AM
HydroZ06's Avatar
HydroZ06
4th Gear
Hello I'm from France and I'm stuck to install infirai, would you be ok to send me in prívate message your brother's-in-law contact ?
Old Sep 4, 2025 | 08:30 AM
HydroZ06's Avatar
HydroZ06
4th Gear
Hello, for the blinkers it's Okay I spliced the wires but the inners lights on both sides doesn't work because I can't plug the Infirai socket to the car... The inners have 2 pins on socket and not 3 like the outers
Can you help me ?
Old Sep 4, 2025 | 08:45 AM
craigyboy's Avatar
craigyboy
you can install the infirai rear lights. I'm in the UK and converted my Friends Euro Spec Z06 to make rear lights work the same as US.. I didnt change anything on the BCM.. I installed the Infirai rear lights and spliced a feed from the Left outer (drivers side) light and connected it to the left inner . Then I spliced feed from right outer (passenger side) light and in connected it to the right inner.
So Both flash red on turn signals and both are brake lights
Old Sep 4, 2025 | 08:58 AM
HydroZ06's Avatar
HydroZ06
4th Gear
Thanks for your answer dude, sorry but it's hard for me to understand which wire did you splice to make light/brake work on the inner light.
I join you 2 images first one for the outer and second for inner which has only 2 pin socket and not 3 like the outer one
Old Sep 4, 2025 | 09:16 AM
HydroZ06's Avatar
HydroZ06
4th Gear
Maybe we can have a call it will bé better to explain me ?
Old Sep 4, 2025 | 09:45 AM
Dano523's Avatar
Dano523
Weeds me out, since its the fastest way to begin with, and only take a few mins in the end.
Old Sep 4, 2025 | 08:05 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Are you trying to get a North American spec car to run Euro-spec Tails or vise versa?
Old Sep 5, 2025 | 02:55 AM
craigyboy's Avatar
craigyboy
I don't have access to my friends car so can't remember how I did it. I've just msg my friend and I'll get back to you.. I'll PM you
Old Sep 5, 2025 | 02:56 AM
craigyboy's Avatar
craigyboy
Its Euro spec car
Old Sep 5, 2025 | 06:36 AM
TheRadioFlyer
Supporting Vendor
Its Euro spec car
Okay, if you want to Easily convert euro-spec to North American spec, you can use a trailer wiring harness converter called "Tail as Turn"
Amazon Amazon
Old Today | 07:28 AM
And-Jac's Avatar
And-Jac
1st Gear
Default Euro to US rear lights
Hi, have the same issue with my car. Installed morimoto rear lights and they dont blink, brake light is fine. Will the trailer module help with this, and how would i wire it? Any help will be greatly appreciated
To Euro to US tail light help
