Trunk Area Lights & Charging
Old Mar 16, 2024 | 11:29 AM
ethans_dad's Avatar
ethans_dad
Default Trunk Area Lights & Charging
Morning CF!
Quick question for the pros here to confirm if the convenience lights in the trunk area eventually turn off when I have the battery maintainer plugged in and the hatch is down in the first latch position? I a not overly concerned as the car is connected to the battery tender, but curious if the lights eventually go off. I think I have I seen the lights still on when looking into the hatch area after a few minutes but didn't worry about it. I also tried fully latching down the hatch but it does pinch the cord more than it probably should.
Appreciate the knowledge and have a great weekend!
Old Mar 16, 2024 | 11:39 AM
NortonCO's Avatar
NortonCO
The lights turn off after several minutes, so no issue leaving the hatch gently closed, but not latched. Alternately, while the cord is trapped by the hatch seal, it is not pinched/damaged, so no issue closing and latching the hatch.
Old Mar 16, 2024 | 12:00 PM
Maxpowers's Avatar
Maxpowers
Yup. Mine is on the tender with the hatch up a bit. Lights turn off after about 10 mins.
Old Mar 16, 2024 | 12:48 PM
orca1946's Avatar
orca1946
Thay will go off, so no worry. I do not close it completely, just down.
Old Mar 17, 2024 | 11:33 AM
jlew64's Avatar
jlew64
Is there a reason you guys are not closing the hatch completely?
Old Mar 17, 2024 | 12:19 PM
Squeaky Wheel's Avatar
Squeaky Wheel
I’m guessing to avoid pinching the cord on the battery maintainer. Although I do close mine and have never found that to be a problem.
Old Mar 17, 2024 | 12:22 PM
mdolandese's Avatar
mdolandese
No particular reason. It’s just easier to lift up the hatch without having to pop the button on my fob or opening from the hatch area or the inside. It’s always in my garage with the battery tender plugged in and the lights go out anyway so it really doesn’t matter to me.It always seems like I’m going in there for one reason or another just easier to lift up
Old Mar 17, 2024 | 01:07 PM
jlew64's Avatar
jlew64
Didn't think of that... thank you!
Old Mar 17, 2024 | 09:04 PM
The courtesy lights turn off after 10-15 minutes. It is a battery saving feature.
Old Yesterday | 04:40 PM
JorgeAM's Avatar
JorgeAM
Do they always turn off? On my 2015 model, it feels like they stay on unless I close the trunk all the way.
Old Yesterday | 06:21 PM
mdolandese's Avatar
mdolandese
No it should turn off after 10-15 minutes. Doesn’t matter if hatch is open or closed
Old Yesterday | 07:02 PM
calvins's Avatar
calvins
Oldtimer
They turn off after a while. I use a Battery Tender Plus and don't even latch the hatch, just lower it. Thing I like is if I get in it without removing the plug and closing it up, it reminds me.
To Trunk Area Lights & Charging
