Anyone using the Wide Angle Paragon Convex Mirrors?
1. Has anyone had any issues with installation (there is a video on their site that I watched)?
2. Has anyone caused any damage mounting or removing these?
3. Is the view so distorted (objects appear further away) that they are dangerous or just not useful?
4. Do you recommend the normal (my plan) or the blue mirrors?
5. Does anyone make a better product?.
Very easy to install, just like their video.
I had no damage removing the old ones or installing the new ones.
It took some getting used to the change from the stock to these, but MAN do I love them more. I don't have to lean forward to see the lane next to me, and it's a much wider view. Haven't even thought about going back to the stock ones.
I used the normal ones, can't speak to the blue ones. The normal ones have a darker hue to them from the stock ones, assuming it's to make up for the auto-dimming loss, but it's not too dark.
The only other product I saw was from Sandyeggo products that are cheaper, but didn't want to add them to the stock mirror. If I hadn't went with Paragon, I would have done these.
I've had Sandyeggo on both sides since they became available, and love'em. No tint on mine, and they work fine- the wide angle aspect makes headlights behind me appear dimmer and so I'm fine without auto dimming. We drive our car in all sorts of weather, the lack of mirror heat has never been an issue for us.
We put the Sandyeggo mirrors on several years ago and find that driving is much more relaxed now.
My eyes are sensitive to glare, but with the Sandyeggo mirrors (not tinted) I don't miss the auto dimming feature at all. The wide angle makes headlights behind smaller and therefore "dimmer".
You could buy a Sandyeggo driver side and temporarily tape it in place for some quick night time testing. Possibly return if not wanted, or sell to recoup some of your money.
Since I haven't tried the Paragon mirrors, I can't comment on the advantages/disadvantages of their tint.
With either mirror, you need to be careful while learning that "Objects in Mirror are a LOT Closer Than They Appear."
OP, thanks for sharing the Paragon mirrors. I'm going to investigate those.
- Avoid using any metal or hard tool that may scratch the original glass.
- Using a hair dryer, heat the glass until its hot to the touch.
- Spray WD-40 liberally into the gap between the back of the Panoramic Mirror and the original car mirror. Let soak for several minutes.
- Use a thin strong thread, fishing line, or dental floss to saw back and forth against the tape.
- Apply more heat and WD-40 as needed.
- Once the tape is sawn through, any adhesive residue can be cleaned off the original glass using acetone or 3M™ Adhesive Remover. DO NOT allow these chemicals to contact any painted surface!
- Once you have gotten most of the tape residue off, use soapy water to clean off any traces of both the tape and WD-40 and then use a towel to wipe the surface dry.
