[Z06] Transmission Mount
Transmission Mount
i replaced my motor mounts to oem ones and now the flanges on the cats and mid pipe rattle on the tunnel plate when accelerating hard...
do the trans mounts actually go bad like the motor mounts? also getting vibration in the shifter when accelerating hard
2006 stock zo6 100k miles
Supporting Vendor
- loosen the exhaust bolts at the head(s)
- wedge a small prybar or thick screwdriver in between the tunnel plate and exhaust flanges
- retighten the exhaust bolts again at the heads
- pop out the screwdriver
You may need to do it again if you don't introduce enough clearance the first time.
Aardwolf (05-22-2024)
It's a common problem and this has worked for me on a few Z06s:
did you loosen the mufflers to the mid pipe too ?
Supporting Vendor
Did you loosen the entire exhaust to fix it or just only loosen the exhaust manifold on both sides? I need to fix this rattle as well. It's driving me nuts.
manifold bolts, then put prybar between flange and tunnel plate…. only did one side at a time… previous times i did both at same time and it never worked
pdc001 (05-23-2024)
Prybar needs to be in there when the H pipe bolts are loose - that meet up to the catted section - not the bolts on the head.
And as with anything rubber the trans mount can go bad but that’s most likely not your issue here
pdc001 (05-23-2024)
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
I had this same thing after my head swap (manifolds off of course)...the flanges touched the tunnel plate.
I used my angle grinder to trim the flanges a little...
