Another Trans Problem
I had my three year trans maintenance completed last week on my '21 (flush/filter and new fluid) and car ran great coming home from dealer. Busy week so car sat in garage all week until yesterday when I wanted to take it for some errands. Started up and would not go into reverse. Hit the R button and it blinked a few times and went back into P. It would engage forward and move but everything I tried would not get it into reverse. It thru a CEL and the screen said "Service Transmission" and "Idle Creep Temporarily Disengaged". I tried a number of things including the door reboot and nothing worked. Pulled the code which is P0700 (General to trigger CEL), and P073E, "Failure to Engage Reverse". Did an internet search and found that there were a number of posts with the same issue but only one that had a followup with a dealer repair that worked which was a valve body replacement (one guy said he just decided to sell his car to Carvana ). Several did say to let it sit overnight which I did and yes when I tried this AM it went into reverse gear ( CEL still on) so I decided to take it for a short run and it almost passed that test with one exception. Close to home I was going about 65 MPH in auto mode with the trans in 8th gear and then slowed to about 50MPH and gave it some throttle and it would not downshift (pushed to floor and nothing), pulled the left paddle and it went down like it should. Tried this again and could not get it to repeat. I will be calling the closest major dealer on Monday which is Hendrick's flagship store City Chev. figuring they have seen quite a few for warranty work and given their connection may be able to get parts within a reasonable time. Collective thoughts would be appreciated before I go to dealer on Monday. I promise to update on what solves this issue. Thanks guys!
drheim (05-01-2024)
The following 5 users liked this post by jagtoes:
Avanti (04-29-2024),
Fast Dawg (04-28-2024),
johnodrake (04-28-2024),
khearon23 (04-27-2024),
kromdom (04-27-2024)
Weird Joe. Could it be the 'flush' procedure freed up something and caused the problem?
Could another 'flush' clear out any debri and fix the problem? Would this be worth a try by the dealership?
Best wishes. Hopefully nothing worst than a valve-body and especially no transmission replacement.
dohabandit (04-27-2024)
Ron_Attleboro_MA (04-27-2024)
Sounds very similar to an issue with mine. They replaced the valve body (after waiting five weeks for the part to arrive), and it appears to have sorted out the issue
Update: Took the car out late this afternoon and it is operating perfect. When went leave I still had my scan tool hooked up and it thru the sub code from before service which is P0286. So I come out of the store to go home and NO CEL anymore. Got home and the only codes were the original two. Got to love these computers on wheels.
drheim (05-01-2024)
I had a CEL on mine in the first 2k miles. It was a P code related the DCT and a sensor/voltage out of range (too high).
I did a DCT filter change at 1500 miles, and it cleared on it's own without any other service work done, and no issues since.
Received 19,482 Likes
'20-'21-'22-'23-'24
Moving this to C8 Tech for further discussion.
I followed your thread and didn't remember you had that lag time. My car has had the shift control on the console replaced about two years ago so maybe I am facing what you just mentioned, ghost codes . I am still going to talk to the dealer and see if they want to take a look. Fortunately the two codes are still stored even though the CEL has extinguished itself so the dealer can see those. The dealer will still have proof of the CEL because the P0700 code is generic for triggering a CEL. I wish the third code was still there because it referenced the "Pump B" having a problem. I still have four years on the power train warranty due to it being a CPO car so I have time to see if things come back. I just don't like the possibility of not being able to get reverse in the future.
Glad that worked out for you and hoping for the same outcome. My recent filter change was the second for the car being the first one was the free one.
Post #409, such a good number from the past.
Curious why you replaced the DCT filter at the 3-year mark. The DCT fluid change is required to be changed at 45,000 miles or 3 years, whichever comes first, but this does not require a DCT filter swap. Assuming your first DCT filter change was between 7,000-8,000 miles, the next filter change would be due at 22,000-23,000 miles. To maintain warranty, will you have to change the filter again in 5,000 miles?
There's no stated requirement from GM that the 2nd filter change has to be within +/- 500 miles of 22,500. That interval is only spec'd for the first filter change when, presumably, you're getting critical break-in wear particles (and if you believe the internet, left over manufacturing debris) removed from the fluid.
Received 5,255 Likes
The thing is, ever since the C5s (at least) there can be rare electronic flukes. Many of us have seen some sort appear once or twice and never again... or very infrequently. I once had a dealer see a code flash up and disappear, not set, and never seen again. So, let's hope...
Simple answer why I replaced the filter was because why drop everything for the fluid change and then come back and do it again in a few miles for filter. I won't be anywhere near 45,000 in three years so I will do the filter again early when it is next due for fluid change in three years. It is easy and simple to remember that every three years I do the entire job and not worry about it. Given the number of grit problems I have no issue doing the filter more often to play safe. And besides the cost to do the entire job was $790. out the door for everything (my engine oil/filter was on GM CPO).
