White Smoke On Deceleration On Dyno
Had my car on the dyno for the first time today! I noticed alot of white smoke coming out of the exhaust on deceleration. Is this normal? I have a tune on it and headers, x pipe, with a slp axleback. Thanks!
Received 19,591 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech for comment.
Slo.c5 (05-04-2024)
If it smelled like coolant then it could be a coolant leak into a cylinder. If it engine is ok otherwise, it could be an overly rich condition, excess fuel on deceleration. Sometimes unburned fuel will look like white smoke.
Slo.c5 (05-04-2024)
Headgasket is my guess. Start pulling spark plugs and look for one that does not look like the others.
If the brake booster leaks it can suck brake fluid from the master cylinder which will be drawn into the engine under high vacuum and burn it resulting in white smoke. If the brake fluid level is stable then this isn't the cause.
I think this might be the issue. I should have specified when I said tune I asked the guy to make it backfire on decel so I could pop flames lol. Still was not expecting that much smoke. Guessing this is it because I recently had my head rebuilt but I will check everything else!
Maybe I’m just getting old, but tuning to purposely backfire 🙄. You be you and all that stuff, but I’m seriously hoping your like 18-21 and just going through some stuff.
