Rotisserie or body dolly?
So I'm probably going to start a body-off restomod on my '69. Is a rotisserie worth it? I've seen the plans for body dollies, but this is the first time I've taken the body off anything, so I'm pretty clueless as to how much difference it would make.
Thanks,
Simon
Thanks,
Simon
A rotisserie is a lot more expensive than a simple lumber dolly. IMO, a rotisserie for a fiberglass body is also a lot more complicated to design to ensure the body is properly supported throughout the rotation.
C3Cliff (05-13-2024)
When I was operating a restoration business, I had a rotisserie as well as several body doilies. While it was easier to do cleaning and small repairs on the rotisserie, there wasn’t anything that I could also do on the body dolly (although it might require a bit more effort). Considering the amount of space the rotisserie took up, it’s no wonder that it was among the first pieces of equipment that I sold when I officially shut everything down. Never missed it and still working on cars (albeit, for myself).
If you have unlimited space and funds, yeah, the rotisserie is pretty cool… Fact is though, you don’t need it.
Also worth mentioning that I didn’t build the wooden monster dollies that seem to be relatively popular (I get it though, they’re cheap to build). I got all of my body dollies from a company called NuAir…. Light weight, aluminum extrusions that are light, strong, and easy to move around. Highly recommended.
Regards,
Stan Falenski
Regards,
Stan Falenski
Regards,
Stan Falenski
Regards,
Stan Falenski
Regards,
Simon
Old Pro Solo Guy
If you want to clean / repair the bottom of the body shell, you can do it standing up with a rotisserie, and at arm's length.
On a body dolly, if you get it high enough, you can still do that work, but all the dust, water & muck will be raining down on you.
I had a high bay shop when I lived in Florida and I used cheap winches from Harbor Freight, attached to the steel roof trusses to lift the body high enough to work under the body while standing up.
If you have a lower ceiling, perhaps raise high enough to sit on a rolling chair.
