Trippin' The Z07
Trippin' The Z07
Hey Folks,
As most of you know the Z07 is pretty stiff and has tires that are marginal in wet weather. Despite that, that damn guy is planning on driving one from Houston to Burbank this summer.
Since he will be heading west, it is expected that the chance of rain will decrease the further he goes. However the trip back will likely be with increasing chance. Besides weather mode or different tires, have you folks any ideas?
The trip to will be in three parts and the trip back in at least as many.
Thanks for any thoughts,
Robert
Robert
To your question, I might add a little more air to the Cup 2s if you use them (see below) -- would go slightly over the 35 if rain is expected. And then be very careful. Damp roads as in a little rain shower won't be a real problem - done in a few times without issue. Standing water/puddles will lead to hydroplaning before just about anything else on the road,so that is where the care needs to come in. Outside of that weather mode is excellent.
As for stiffness - Set up My Mode to keep suspension in Tour, with whatever else you like to try to keep it relatively calm.
Thing is, may very well need tires anyway. Looks like that is about 2200 mile round trip plus any stops and such in between Think Cup 2Rs probably have 4-5k in them (depending upon use), so if starting off with any mileage, they more not make the entire trip anyway. At that point, might as well plan on tires before hand -- or better yet, order some to be delivered out west and have them swapped on for the ride back. Get a set of the 4s for the trip and other things and can always go back to the 2Rs or grab another set of wheels (used OEM ones getting cheap) for the other set.
Yes get some better tires.
Dig
I would not chance it … and I’m a gambler running drag radials. You could be off in a ditch real quick. Or sitting in a parking lot for hours until the rain stops and it clears up
Good point about the tire wear, will see if somebody can get 4S in time. I can see where adding air will allow the grooves in the center of the contact patch move outward. Is there something else more air does?
Thanks for your thoughts,
Robert
Well, if it's a parking lot where there's a building with adult beverages then not so bad:-)
Yeah, I have My Mode set with the suspension on Tour and other things on Sport.
Robert
Robert
robob (05-10-2024)
Ordered the 4S so that will help.
BTW, I am not recommending this as there may be safety implications on the street, but I run the Cup2Rs at 32psi on the street. Dealer had them at 40 and above.
Thanks again folks,
Robert
Thanks again folks,
Robert
32 is probably great on the street. If you know you'll be in the wet, add a little if you can.
robob (05-10-2024)
Received 4,101 Likes
Weather mode is your friend
robob (05-12-2024)
Robert
Robert
The following 2 users liked this post by CaryBob:
Big Lebowski (05-13-2024),
robob (05-13-2024)
Weather Mode also adjusts not only throttle progression but also the traction controls. At the driver school at Spring Mountain, they show you how easily you can break the rear end loose on a wet road but how difficult it is to do that in Weather Mode. Most people will not be able to do it as long as Weather Mode is active. So in wet weather, it’s pretty much a must.
