C6 Parts for Sale/Wanted C6 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Sponsored by: C7 Carbon
WTB: 7-spoke Chrome Wheel Center Caps
Old Oct 30, 2024 | 03:04 PM
eric_'s Avatar
eric_
3rd Gear
Default 7-spoke Chrome Wheel Center Caps
Want to buy a set of 4 center caps for the 7 spoke GM forged wheels on the C6 Hertz/ZHZ version (same center caps as the 15-spoke forged chrome wheels also). GM parts number 19132700, number on the backside of caps is 88966047. These caps have an outer diameter of 2 5/8" (same as OEM base wheels) with inner diameter of 2 3/8" (different from OEM base wheels). Sample pictures as shown. I'm located in Lafayette, IN, please PM me if you have them. Thanks
Old Oct 31, 2024 | 08:21 AM
RayCE's Avatar
RayCE
I think I have 3 sets in the garage...I will post what I have so you can see if its what you are looking for.
Old Oct 31, 2024 | 10:04 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Having done a lot of research (and spent a lot of money), the saga of C6 center caps is a long and complicated one. There are at least seven different ones (flat silver on a flat cap, sparkle silver on a concave cape, flat silver on concave, grey (the standard for most polished and chrome wheels), plus a couple of special editions. All are the same size and fit any wheel with the simple cap (not the original base and Z06 wheels that used "hub cap" type closeouts. (They also fit C5 and C7 wheels since I am running a set of C6 caps on my C7 wheels now.) The truly disturbing thing is that GM has changed the caps with the same part number over the years (I orded nine specific part numbered caps, all arrived in sealed packages, but there were three different styles depending on the year of manufacture).
Anyway, here are some photos of a set I have available if they are of interest. All four are brand new.
Old Oct 31, 2024 | 10:08 AM
eric_'s Avatar
eric_
3rd Gear
Do you know what the inner diameters (measure from clip to clip) are for these caps? The wheels I have uses 2 3/8" inner diameter (OEM base wheels use 2 1/4") with the clips being roughly 1/4" tall (OEM base wheel clips are also a lot taller at 1/2" from memory) from my rough measurement.
Old Oct 31, 2024 | 11:40 AM
07MontyRed's Avatar
07MontyRed
NCM Lifetime Member
All C6 (indeed, all GM) wheels have the same center cap dimensions, In fact, the black portion that fits into the wheel is the same part number on all GM wheels (except those using oddly shaped center hubs).
Here is the back of the ones I have ... its the same on all two dozen different caps I have, plus a friend Cavalier. I had a set of the 7-spoke wheels and changed center caps several times.
Old Oct 31, 2024 | 11:57 AM
eric_'s Avatar
eric_
3rd Gear
Are these wheels the same ones you fitted these caps on?
I had some reproduction wheels on my car when I got it and I can't confirm the dimensions with an OEM wheel sadly, so I want to make sure it will fit.
Old Nov 1, 2024 | 04:39 AM
07MontyRed's Avatar
07MontyRed
NCM Lifetime Member
Those appear to be normal GCA seven-spokes so no reason the caps should fit. However, since you seem to have convinced yourself that you need special caps for whatever reason, I suggest you keep looking. Good luck.
Old May 29, 2026 | 05:40 PM
ZHZ327's Avatar
ZHZ327
2nd Gear
I have a ZHZ and need one of these. One de-laminated and the chrome part is gone. It is the thinner type as Eric shows in the original thread. I purchased a thick one and it does not clip in.
Old Today | 07:09 AM
HOUSEOFWHEELS's Avatar
HOUSEOFWHEELS
Supporting Vendor
St. Jude Donor '03 & '11
I believe I have a new set of these.125.00 set of 4 shipped
Bob
House of Wheels
561-445-7606
To 7-spoke Chrome Wheel Center Caps
