Engine Mods Outrageous Builds, High-Horsepower Modifications, strokers, and big cams for the Corvette
Harmonic balancer - Installation
Old Nov 25, 2024 | 09:07 AM
Bandit 2010's Avatar
Bandit 2010
Default Harmonic balancer - Installation
Harmonic balancer Bolt ? Should one use red lock tight when installing ? told to torque to 75 ft lbs ? Anyone have any experience with this ? thanks
Old Nov 25, 2024 | 03:36 PM
Bandit 2010
thanks guess no one here has any experience with installing a balancer bolt ? thanks anyway try elesewhere for an answer
Old Jan 3, 2025 | 05:52 PM
jrodgers's Avatar
jrodgers
3rd Gear
Default Harmonic Dampener
I replaced the harmonic dampener on my C5. I installed a new ARP bolt. When installing I used red lock tight and torqued the bolt to 240 ft lbs per the instruction sheet that came with the dampener.
Old Jun 13, 2025 | 09:44 AM
Orion2011's Avatar
Orion2011
ARP bolt with ARP lube torque to 240 ft-lbs.
Old Jul 25, 2025 | 10:21 PM
Rebelyell's Avatar
Rebelyell
I know this is an older thread but thought I'd try to bring some clarity with experience.
I just looked in my GM Powertrain service manual covering the newest iteration of Gen I sbc: RPO L31 Vortec 5.7L aka iron head Vortec 350.
Crankshaft Balancer Bolt torque spec is 70 lb ft Repeat 70 lb ft *** AND ALSO: NO thread locker is recommended Repeat NO Thread Locker
There's little difference between C3-era 350 crank snout and/or damper/balancer hub and those of L31. Seems tightening balancer aka damper bolt to 240 ft-lb goes beyond excessive and may damage/strip threads in crank snout. FWIW, first several years of sbc had absolutely NO bolt & NO bolt-Hole at all; balancer was merely pressed on.
** the above is Not intended for Gen III or IV or V motors; the above is for GEN I and II only.
Old Oct 20, 2025 | 08:12 AM
NORTY's Avatar
NORTY
Later Gen engines, you might want to pin the HB, especially if you go with power adders.
Old Yesterday | 11:48 PM
socal_tom's Avatar
socal_tom
Use blue not red or you will never get it off
To Harmonic balancer - Installation
