[Z06] Stock Oil Cooler Replacement
Thanks.
The DeWitts with IOC and ITC isa great setup for the street and worked "OK" for me on the track as I added 133 NA rwhp at the same time when the DeWitts was installed. Again higher than I wanted but OK at 285* oil temps and 245* water temps including running the LG vented hood to move more air thru the radiator.
50% smaller and mounts in same location, gets oil temp up driving around but still provides cooling.
those quick connect clips and fittings are a bitch, pick up some extra clips before you start
Thanks.
i would either replace it with a stock Z06 cooler, slightly smaller Z51 oil cooler, or the oil thermostat kit......
Change your oil often and use a top quality true synthetic oil like Amsoil, Pennzoil Ultra, Sunoco European formula (commericall grade), etc...Most mass market USA oils are NOT true synthetics....they are highly refined Group III conventional oils which are more susceptible to lower oil temps.
My 10 Z06 does take a bit to warm up the oil to 180 degrees but my 2020 AMG GTC does, as well. I would never delete the oil cooler on either........
The stock cooler on these cars is almost too efficient, especially street driving or cooler weather, and the oil can take forever to get some heat in it.
This cover goes over the factory oil cooler and blocks some airflow. It is two pieces, so it is easy to print and install.
I know it fits my 2006 Z06. It should also fit 2007 and probably 2008 cars with the same cooler setup, but I have not personally tested those. Later C6 cars may be different, so compare your setup before printing.
I’d print it in something that can handle heat/outdoor use, like PETG, ASA, ABS, etc. Definitely not PLA.
Thingiverse link:
https://www.thingiverse.com/thing:7372914
As I have mentioned, previously, I would not eliminate/block the factory oil cooler but if you insist would invest in a oil temp regulator that keeps the oil temp, max, 200 degrees on the street.
When you are running true high-tier synthetics, the math and physical behavior of the fluid change drastically. Along with the precise technical nuance of how those specific oils behave at 175°F–180°F:
1. Viscosity and Fluid Dynamics (The 0W Advantage)
The primary concern with low oil temperatures is typically excessive viscosity (the oil being too thick to flow properly into high-load zones, like the LS7's tight lifter buckets or valve guides).- A true Group IV PAO (Polyalphaolefin) like Amsoil Signature Series, or a heavily refined Group III+ / IIIb Gas-to-Liquid (GTL) base stock like the Castrol Edge European Formula (German/Belgian imports), have exceptionally high Viscosity Indexes (VI).
- Because they use a 0W rating built on incredibly uniform molecular structures, their viscosity curve is much flatter than a standard fluid.
- At 175°F (approx. 80°C), a high-VI 0W−40 flows exceptionally well. Its kinematic viscosity at that temperature is only marginally thicker than it would be at 212°F. It is safely within the exact operational parameters required to protect the valvetrain, maintaining excellent flow velocity without creating the dangerous pressure spikes or heavy filter-bypass situations you'd get with a conventional oil.
2. Moisture and Volatility (The "Boil Off" Nuance)
The classic argument is that oil must hit 212°F to boil off water. However, physics dictates that water evaporates at any temperature; it just does so faster at higher heat.- True synthetic base stocks have incredibly low Noack Volatility percentages. This means the oil itself doesn't burn off or vaporize easily, but it allows trapped moisture to release efficiently.
- At 175°F–180°F, as long as the engine is driven long enough to reach full thermal equilibrium (meaning it stays at that temperature for 20–30+ minutes rather than short 5-minute trips), moisture will steadily vaporize out of the crankcase via the PCV system. It doesn't require a violent boil at 212°F to clean the sump, provided the oil's additive package resists emulsification, which both Amsoil and Castrol Edge Euro do masterfully.
3. Modern Additive Chemistry Activation
While older generation ZDDP and anti-wear packages required massive thermal energy to activate and bond to metal surfaces, modern high-end synthetic formulations utilize highly reactive, advanced zinc variants and co-additives (like boron or molybdenum) that initiate surface passivation and protective barrier formation at much lower thermal thresholds—well below 175°F.The Adjusted Verdict
If you are running an elite fluid—whether it's a true PAO/Ester Group IV or a high-tier European GTL formula—a stable 175°F–180°F oil temperature will not cause harm. The film strength remains ironclad, the fluid is fluid enough to prevent accelerated wear, and the chemistry is sophisticated enough to manage normal combustion bypass. The only real caveat left is ensuring the car gets regular, sustained highway mileage rather than short, intermittent heat cycles, allowing the PCV system to do its job pulling out moisture at that lower thermal threshold.Last edited by jb78L-82; Jun 21, 2026 at 02:46 PM.
Thingiverse link:
