The time has come! 416 and whirly birds
I'm happy to say I have finally sent my car to be fixed. For those that don't know my story, I had fuel injector issues (gen 1 FIC 30%) that I fought with for a while trying to figure out what the issues were. We finally changed them out to the Gen 2's, which kuddos to FIC for swapping them out and got it running perfect. Sadly it was too late and the short block gave up the ghost. Pulled everything apart this week and found the infamous thrust bearing was the issue.
So on to the positive stuff. Car is now getting a fresh new LME 1400 hp 416 built using my block. Also a new port injection fuel system with a triple in tank pump. Last but not least 2 Xona rotor XRC6869S turbos. The turbo kit is by Performance Supercar. it is nicest kit I've seen that can be ordered and installed by yourself or your shop (https://performance-supercar.com/pro...41942973251653). We are going with the DSX atlas controller for the port injection. I'm pretty excited for this build. The turbos will be more than I need for now, but later it can be turner up with the proper parts. I'll be sure to update this as the build comes together.
Just a heads up I will have a ton of parts from my previous build which was a max effort LT4. Kong x port super charge with all the pulleys, Cordes ice tank, heat exchanger, Mighty mouse wild catch can (1200 hp), 103 NW tb, Cordes 5" CAI, Alky Meth Kit with brand new pump, American Racing 2" headers, FIC Gen 2 30% inj, JMS voltage booster for lowside fuel pump, DSX aux lowside, LMP lid. Itd be a great package if all bought as one. Everything someone would need minus the cam kit. I'm also changing the cam out. Its a "rowdy" custom spec cam by MTI.
Cant wait to hear how it turns out. How much do you think this round will cost with the system installed?
