Cicio Performance - Another C700x Twin Turbo C8 Build Completed!
Sharing the completion of yet another C700x Twin Turbo C8 build here at Cicio Performance! If you've been following our journey throughout the years, you know this is far from our first rodeo with the C8. Over the years, we’ve had the privilege of working on countless C8 Corvettes with packages ranging from 600whp to +1100whp that are street friendly, and with each build, we continue to perfect our craft. Day in and day out, we’ve honed the process, making every project more refined and reliable.
There’s just something incredibly rewarding about pushing the limits of what’s possible with the C8, while also ensuring the car remains as reliable as ever. And let’s not forget, all of our builds come with a lifetime warranty on the engine and transmission, giving our customers peace of mind to enjoy their cars without worry. Nonetheless, this build specifically only takes 10-15 business days to be completed!
Highlights of this C700x Twin Turbo build:
-Cicio Performance X-pipe Exhaust Version Twin Turbo Kit
-Xona Rotor Turbos
-200 Cell Cats
-Dodson Superstock 7/8 Plate Clutch
-HP Tuners ECU Unlock
-Custom Cicio Dyno calibration
-Motul Oil Change
-One Step Colder Spark Plugs
Let's not forget that the Xona Rotor turbos that we run are engineered for unmatched efficiency with cutting-edge science. If you know then you know!
Make sure to check out the attached videos below that include the car’s first cold start and a dyno pull!
Fun Fact: Customer got a custom made plate beforehand to be ready for when the car came out the shop. Good one!!
Thanks for your continued support. We’re excited to keep bringing you more jaw-dropping C8 builds!
Ready to build your C8?
Sales@CicioPerformance.com
678-297-7770 GA
813-586-2305 FL
~Luis @Cicio Performance
Here you go my friend!
We do not have a "before" graph for this one. However, they generally make around 440whp on our dyno.
I'd assume a 230-260whp increase with our C700 package before we start running out of fuel system.
Best thing about this build is that it comes with a Lifetime Warranty on the engine and transmission!
~Luis
This is helpful. The reason for asking for a before and after is to compare the same Dyno read (average being 435-440 I've seen factory Dyno as high as 460).
Seems to be a great gain. Has there been any progress in the industry regarding transmission tuning or are we still in the waiting game. Additionally, what supporting mods are recommended for this kit on the c8 platform?
~Luis
A good supporting mod we'd recommend to add with our 603R and C700 packages is a Dodson TCU Pressure Control Module since our packages already come with everything you need to make good reliable power. That's about it before we start talking about upgrading to our Auxiliary Fuel System!
~Luis
This one has the addition of our X pipe version kit which is a $2,000 upgrade making the total out the door installed & tuned $34,995!
Have I mentioned that this package also comes with a Lifetime Warranty on the engine and transmission?
~Luis
Discounts are still active for our C8 packages!
603R $24,995
C700 $32,995
C900 $59,995
This is installed AND tuned.
678-297-7770
~Luis
That being said, this package is capable of mid to low 10s at +130mph given the right conditions.
We strive to provide the best customer experience not just before and during a build, but with post-build support as well.
Thank you for the kind words!
We introduce this fuel system in the C900 package or above.
603R $24,995 installed & tuned
Cicio Spec Twin Turbo Kit
Xona Rotor Turbos
Cicio Custom Tune via HP Tuners
C700 $32,995 installed & tuned
Xona Rotor Turbos
Dodson Clutch
Sport Cats
Motul Oil Change
One Step Colder Plugs
Both come with a Lifetime Warranty on the engine & transmission which protects against catastrophic failure.
603R $24,995
C700 $32,995
C900 $59,995
678-297-7770
~Luis
