200+ MPH C4
Old 02-13-2003, 08:32 AM
johnboy89
johnboy89's Avatar
Default 200+ MPH C4
What kind of horsepower at the flywheel (and gearing) would it take to push a C4 past 200 MPH?
Old 02-13-2003, 08:51 AM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
Default Re: 200+ MPH C4 (johnboy89)
Alot! :D
I think I read somewhere that 80% of the HP after 150 MPH goes towards air drag, so to get another 50MPH you better have some serious power/*****.
I would guess that a 700-800HP motor would have enough, but you better examine your head if you go that fast or attempt to :skep:
Old 02-13-2003, 08:57 AM
The Hobbit
The Hobbit's Avatar
My local dealer has what is claimed to be the second fastest Callaway ever built, no 1989-010, posted speeds are 0-60 in 4.1 and 215mph. quoted horse power is 584.
If you want it its yours for 40, k GPB
Old 02-13-2003, 09:39 AM
Dan Parker '96
Dan Parker '96's Avatar
It took Car and Driver a Lingenfelter built small block 427 and a smidge over 600hp to take a stock bodied C4 (with mirrors and it may have been lowered a bit) to over 200.
Old 02-13-2003, 09:58 AM
Zora
Zora's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 200+ MPH C4 (The Hobbit)
:skep:
Old 02-13-2003, 10:01 AM
scorp508
scorp508's Avatar
Around 580.
Old 02-13-2003, 10:45 AM
1991Z07
1991Z07's Avatar
Rick Doria peaks around 230 MPH on around 650 HP in the Open Road Races in Nevada & West Texas....
Old 02-13-2003, 11:42 AM
johnboy89
johnboy89's Avatar
Default Re: 200+ MPH C4 (Joe90)
For some reason, I was thinking that it'd take somewhere around 450 HP or so to do this - I realize weight is a big factor as well.
Old 02-13-2003, 12:16 PM
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Curtis Ward in his ZR-1 hit 201 durring a ORR event. He had removed the side mirrors and had the car lowered with a coilover setup, plus he had a top end P&P headers and somehting else. He would have been pushing close to 400 RWHP
Old 02-13-2003, 02:48 PM
black_89_vette
black_89_vette's Avatar
Default Re: (scorp508)
Around 580.
Does that mean around 430 or so and a full bottle of nitrous set at 150? :D
Or would that detonate the drivetrain and tranny hitting the nitrous in 6th? I mean, over 3000 RPM of course.
Old 02-13-2003, 03:01 PM
hngacurv
hngacurv's Avatar
Default Re: (black_89_vette)
The Lamborghini Diablo does it with 492 BHP and 428ft/lb TQ. It is a lot more aerodynamic though. http://www.geocities.com/motorcity/s...blo/specs.html
[Modified by castivers, 3:02 PM 2/13/2003]
Old 02-13-2003, 03:08 PM
johnboy89
johnboy89's Avatar
Default Re: (castivers)
@ 3,828 lbs, it's heavier too-
Old 02-13-2003, 03:18 PM
_freakmonkeydogboy_
_freakmonkeydogboy_'s Avatar
Default Re: (johnboy89)
:withstupid: i'd take one... :D
Old 02-13-2003, 03:54 PM
your drinking buddy
your drinking buddy's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Wieght of the car isn't a factor in top speed, only aero.
Old 02-13-2003, 04:02 PM
TIMSPEED
TIMSPEED's Avatar
Default Re: (vettes rule)
A friend of mine runs his 87 Corvette in the Silver State Classic every year. It's basically stock suspensioned (mostly DRM parts throughout though), lowered, he's got his race weight to like 3100lbs, he has a 377cid stroker motor with a nice set of, if I can remember right, Brodix or Pro Action Lightning Heads, an edelbrock Performer RPM Air Gap intake (last time I checked), a Demon 750cfm Carb, and a nice roller cam. He drives it on the street a lot also (not smog legally ;)). I'd say that car has right around 500rwhp. He has a ZF6 swapped into it along with the factory D44 with 3.45 gears.
Old 02-13-2003, 04:10 PM
johnboy89
johnboy89's Avatar
Weight of the car isn't a factor in top speed, only aero.
... of course weight is a factor - you can't say it would take the same energy to push 1/2 a ton to any given speed, as is does to push 1 ton to that same speed - even if the aerodynamics are similar – I think there’s this thing called gravity that plays into it.
Old 02-13-2003, 04:50 PM
Darkness
Darkness's Avatar
Its true but its not as linear as it might seem, remember the car is already moving, but it sure takes a little more to make it go.
To 200+ MPH C4
Old 02-13-2003, 04:52 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Are you in a rush to get somewhere?:lol: :steering:
[Modified by eamador11, 3:53 PM 2/13/2003]
Old 02-13-2003, 05:03 PM
johnboy89
johnboy89's Avatar
Default Re: (Darkness)
The greater the mass, the greater the amount of energy necessary to keep it in motion.
Besides, I can’t imagine that the drag coefficiency is that much greater (or less as the case may be) between a Vette and a Lamb Diablo. That being said, the 500-600 or so lbs between the two would surly require that much less horsepower to bring a Vette (which weighs less) to 200 MPH than it would a heavier Diablo.
But then again I’m no physics expert – although I do have a theory that defines in detail the relationship between the number of Long Island Ice Tea’s I consume, and my ability to walk.
Old 02-13-2003, 05:34 PM
bill mcdonald
bill mcdonald's Avatar
I think it takes about 550 hp to get a C4 to 200+ MPH. LPE yellow ZR1 had about 550 horse and it was kicking off 217 mph right?
weight has nothing to do with top speed. it only effects how long it takes to get there.
Quick Reply: 200+ MPH C4
