Soler Performance – C8 ERay Upgrades
Ships from AL | Tech Support Available
Hours: Mon-Fri | 8 AM-5 PM CDT
General questions Call/Text: (251) 468-9786
Email: support@solerengineering.com
Tech Support Call/Text: (251) 716-8077
Email: teegan@solerengineering.com
Follow us: IG & TikTok: @soler.performance
Ported & Calibrated Throttle Bodies + DLX Bluetooth Throttle Controller
– Warranty-safe | Plug & Play | Made in the USA –
Compatible Products for Your C8 ERay:
91mm Premium Ported & Calibrated Throttle Body
Improved throttle response, higher airflow, and calibrated for smooth driveability. Direct bolt-on upgrade.
Part #: SE8223-91
SE8223-91mm Throttle Body
95mm Premium Ported & Calibrated Throttle Body
Maximum airflow, enhanced throttle response, and calibration for performance without sacrificing drivability.
Part #: SE9871-95ZR
95+ MM (Plus+Port)
103mm Premium Ported & Calibrated Throttle Body
Built for high-output builds. Delivers peak airflow, crisp throttle response, and refined driveability calibration.
Part #: SE8223-103
103mm High Perf Throttle Body
DLX Bluetooth Throttle Controller:
Eliminate throttle lag and fine-tune pedal response in real time. Fully customizable and Bluetooth-enabled.
Part #: SE0525-TC
SE0525 DLX Bluetooth Throttle Controller
In it, he explains airflow and shaft design, how air moves through our throttle body, and how design choices impact airflow.
Use code TIFF5OFF at checkout!
-Tiffany
The Soler Performance team is off for the holiday, but we’ll be back Monday. Thanks for all the support. Enjoy the time with family, friends, and fast cars!
-Tiffany
(251) 468-9786
-Tiffany
-Tiffany
A common question we get is whether you can connect multiple Soler Performance throttle controllers to one phone or if you need separate apps. You can connect as many controllers as you want to the same app, Soler PRF, on one phone. You can also have them connected to a spouse’s phone at the same time.
As you pair each controller, you can rename it so you know which vehicle it belongs to. The app will only connect to the vehicle you are inside of with the ignition on, so there’s no interference between cars.
This means you can run a controller in your weekend car, your pickup truck, your daily driver, your wife’s car, anything you own, and manage them all easily through one app. I hope this helps anyone who didn’t know and might have been holding off on adding controllers to their whole fleet.
– Tiffany
Discount code: tiff5off
tiffany@solerengineering.com
251-468-9786
-Tiffany
251-468-9786
Think of it more as a multiplier or additive to whatever mode you’re already in. It simply adjusts throttle sensitivity based on pedal input.
If you find you need to be extra gentle on the pedal in Stealth Mode, you can set the throttle controller to Valet or Economy to reduce throttle sensitivity. That can actually make it easier to drive smoothly compared to having it set in a more aggressive mode like Sport 5.
Hope that helps clarify things.
-Tiffany
If anyone has questions about fitment or compatibility, I’m happy to help. Wishing everyone a great holiday week!
https://www.solerengineering.com/generalmotors
Discount Code: TIFF5OFF
251-468-9786
251-468-9786
I'm on the hunt for an Eray, and these will be the first mods.
-Tiffany
Soler Performance
A recent 5 star review that was left on our website for the Soler Performance Throttle Controller:
"You know how you watch YouTube videos and you hear someone hawking a sponsors product and you think, “yeah right, like you don’t have an interest here”. Many occasions I have been fooled by these YouTube so called influencers. Much to my surprise however not only did Soler Performance provide me with an excellent product but they answered all my questions on the phone and through email with professionalism and courtesy. I am as impressed and that is hard to do. As for the throttle body controller itself, if does as advertised and a whole lot more. It truly works. There are several how to install videos on YouTube which are fine but lack key information. However Soler reps helped me through the issues. Not something you see everyday. I will now save up for the 91mm portal throttle body itself which I now believe will even make more of an impact. Be good to the customer and they will be good to you. Soler gets that."
If anyone has experience they would like to share with a Soler Performance product, please feel free to leave your review here:
SP Google Review
As always, we love hearing back from everyone. If you have any questions or concerns, please feel free to reach out.
-Tiffany
Soler Performance
That said, we do recommend pairing them together because they address two different things.
The throttle body improves real airflow by changing the internal geometry. This gives you smoother and more consistent power delivery, reduced lag, and better overall drivability across the entire RPM range. The throttle controller works electronically. It adjusts how quickly the throttle blade responds to your pedal input. It sharpens response and removes the soft or delayed feel, but it does not add airflow or horsepower on its own. It is still limited by the physical throttle body on the car.
When used together, the throttle body fixes the physical airflow limitation and the controller fine tunes how that airflow is delivered. The result is better response, smoother power, and a much more connected driving feel.
Plenty of customers run one or the other, but the TB and TC combo is where you get the most noticeable improvement.
-Tiffany
