I have a factory original 1993 C4 base with an automatic trany. 94k miles and running excellent. Question is, when should I change the trany oil, what intervals are recommended?.
I have a 96 and changed out my original fluid and filter at 40k miles. First, the fluid was 30 years old and Dextron has been improved since then. Second, the filter was 30 years old and I hope they have made advancements in filter media tech. Dan
First check the quality of the fluid. Should be red not brown and shouldnt have a burnt smell. If the atf looks good you should be alright to drive up to 100k minimally but id reccomend you change it whenever you get the time before 100k. Isnt a crazy tough job. Id fully take the pan off and check for any metal debris. Clean the inside and outside of the pan plus the mating surface on both sides. New filter new gasket new fluid and youll be good for easily 40k miles. Just check the fluid every now n then. Also a tube of lubeguard instant shudder fix helps quiet down the entire trans and softens up rough shifts.
The manual states every 15,000 miles, but that is under severe conditions. I do mine every 50K.
One thing I have found is to torque the bolts properly to keep from having any leaks. Also, you can suck the fluid out through the fill tube first to lessen the mess of dropping the pan.
Sucking the fluid out through the fill tube is the way I plan to go next spring. Just have to find a fluid extractor I like. With the service record history I have, the fluid only has around 27k miles on it but is 24 years old.
I agree with sucking it out. The normal cheap Harbor Freight suction pumps have a tube size that does fit in the fill tube and will suck some of the fluid out. If you want to get twice as much out and make the pan dropping even easier here is what you do. Suck out all you can with the stock pump hose. Then tape a 3" section of 1/4" tube to the bottom of the stock tube. The full size hose hits the dipstick stop. The 1/4" will snake around it. Dan
I've read some posts where folks cut the last bit of tube at a 45 degree angle and that usually allows it to get around the dipstick stop. I like your idea better of adding a piece of tube versus cutting the stock tube.
After you suck the fluid out of the pan, you should go ahead and replace it with a GM filter. You can get an OEM GM filter off of Rock Auto.
Because the OEM tranny cooling system is almost nil and you can expect normal operating temps of up to 220f the 15K oil change is always severe duty and should be followed using a quality synthetic ATF which can easily handle the higher corvette temps. A new pan with drain plug will make your maintenance much simpler also.
Looked on Summit tonight. Don’t see a pan with drain plug for $53.
Closest one I could find to $53 was this one for $74.35:
Mr. Gasket Automatic Transmission Oil Pans 9767BMRG
Hmm, I just did quick search on Summit and its now 36 bucks, its the Summit brand gu3886 or similar pn#. google search of 4l60e pan with drainplug gave me 4 pans under 50 bucks in under 10 seconds, so's no shortage..
