C7 Parts for Sale/Wanted C7 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Sponsored by: C7 Carbon
FS: DSC Sport Controller and Tractive shocks
Old Nov 16, 2025 | 02:31 PM
Eimarshall's Avatar
Eimarshall
Default DSC Sport Controller and Tractive shocks
I have a DSC Sport controller(V2 i think) and a full set of DSC's Tractive shocks for sale. They all came on the car when I bought it. I swapped to coilovers for more dedicated track spring rates and control, so these are up for sale. I believe everything was on the car for around 8k miles (installed in 2017). I took the car to several track days this summer, so they have seen some abuse, but overall appear to be in pretty good shape. no weeping or anything. There are a couple scuffs on the shock body threading due to my poor handling during removal. (whoops).
I'd like $2800 for the set but I'm open to offers. I'm willing to ship as well.
PM me or drop any questions in the thread.
Old Dec 1, 2025 | 09:38 PM
Eimarshall's Avatar
Eimarshall
Bump for the holidays
Old Dec 18, 2025 | 01:58 PM
Eimarshall's Avatar
Eimarshall
Bmp for Xmas.
Old Jan 10, 2026 | 10:52 AM
Eimarshall's Avatar
Eimarshall
Bump
Old Jan 11, 2026 | 02:20 PM
6466C7's Avatar
6466C7
7th Gear
Would you sell the controller separate? I wonder if they’re preprogrammed to the tractive suspension. I see they ask when you buy the controller but offer warranty and support for $350 if you buy second hand
Old Jan 11, 2026 | 07:03 PM
Eimarshall's Avatar
Eimarshall
They can be reprogrammed fairly easily. I found several tunes and such on this forum. Setting the MRC or Tractive calibration doesn't appear to affect the rest of the tune either.
I would really prefer to sell it together. Unless you know of someone who already has the controller and wants the shocks....
Old Jan 11, 2026 | 07:20 PM
6466C7's Avatar
6466C7
7th Gear
If you decide to separate the controller let me know, I’m very interested located in Michigan. I don’t doubt you’d be able to sell the shocks in the “Corvette Track enthusiasts” facebook group as it’s a track oriented group or any of the other C7 specific ones. I could list some more if you’d like. Obviously using Paypal to avoid scammers.
Old Feb 4, 2026 | 03:36 PM
Eimarshall's Avatar
Eimarshall
Bump
Old Feb 22, 2026 | 04:28 PM
JRL's Avatar
JRL
PM Sent
Old Feb 23, 2026 | 12:04 AM
Eimarshall's Avatar
Eimarshall
Replied.
Old Feb 24, 2026 | 11:55 PM
TheBonfiggy's Avatar
TheBonfiggy
Is the DSC Controller only for cars with factory magride? Or is it like a standalone type deal and works on either?
Old Feb 24, 2026 | 11:57 PM
Eimarshall's Avatar
Eimarshall
No. its only for magride. It uses all the factory sensors and such.
Old Mar 23, 2026 | 03:26 PM
Eimarshall's Avatar
Eimarshall
Price drop bump
Old Mar 24, 2026 | 10:07 AM
SuzukiDan7's Avatar
SuzukiDan7
So these are basically better than OEM magride shocks , designed with track use in mind, but not as good as dedicated track suspension?
Old Mar 24, 2026 | 11:39 AM
Eimarshall's Avatar
Eimarshall
Pretty much. Sort of a halfway point.
There selling point is that the Tractive shocks utilize a mechanical valve that doesn't overheat or have latency/lag like the OEM magride shock have been shown to do. The DSC controller allows you to tune the characteristics and has some impressive option to do so. That said, like any shock, it is designed to operate with a range of spring rates and has minimum/maximum compression/rebound settings unless you get it re-valved. I decided to add some significant aero and based on how the car had been performing without it, decided to go with much higher spring rates than the OEM leaf springs. Rather than try to get the tractive shocks re-valved and fuss with the dozens of tuning parameters on the DSC system (and the need to add spring collars and such to the shocks), I got a deal on a set of used Penske 8300s with proven springs/valving for a similar setup.
Now, I never drove this car with the OEM suspension (bought it used), So I can't speak to how much of an upgrade the Tractive system is over OEM. But If your street/track ratio is more track oriented but you still want the comfort of street manners at times, These are likely a solid upgrade per others reviews and comments.
Old Apr 4, 2026 | 04:06 PM
Eimarshall's Avatar
Eimarshall
Spring break bump.
Old May 2, 2026 | 07:35 PM
Trackout's Avatar
Trackout
Hello. I don't see spring perches on them. Are they not the Tractive coilovers that you can combo with the DSC controller?
To DSC Sport Controller and Tractive shocks
Old May 2, 2026 | 07:38 PM
Eimarshall's Avatar
Eimarshall
They are the tractive shocks. No spring perches. These were originally installed prior to the coilover version being available. I've been told DSC will sell the perches separately.
Old May 2, 2026 | 07:45 PM
Trackout's Avatar
Trackout
Ok, thank you for the quick reply. I'll contact them Monday and see what it would take to get them moved over to some 800lb springs (if they have them) and recalibrated for my set up. My current FE7 suspension and factory LCA bushings are being overwhelmed by my faircloth composite splitter and ZTKXL rear wing. it's changing the alignment geometry in the esses, turn 6 and hog pen badly at VIR and instead of quicker times, I'm struggling to man handle the car to 1:59s. I'm over a second off my pace. Im' going to go monoball and upgrade the suspension to either mechancial like you, or to a set of tractive with the DSC.
Old May 7, 2026 | 04:21 PM
Eimarshall's Avatar
Eimarshall
Price drop.
