[C2] O ring caliper conversion
Old Dec 12, 2025 | 05:42 PM
Charles55's Avatar
Charles55
Default O ring caliper conversion
Last test drive after red wire replacement, car pulls to the right. No visible leak at caliper but rotor felt slippery. Pulled the pads, they were wet. Took caliper off , pulled seal. And jelly like goo behind pistons. Off to Zip to get o ring conversion kit. They only had 1 kit. Checked online several vendors list them, cssb, lone star, and top flight. Prices and shipping vary. Question is are they all the same ( one manufacturer several marketers) and how do you identify what brake fluid is in system? Thanks Chuck
Old Dec 12, 2025 | 05:46 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Call Ken at lone star and get the kit
Old Dec 12, 2025 | 06:41 PM
Scott Marzahl's Avatar
Scott Marzahl
Ken or I prefer Lonnie at CCSB, great quality parts and service.
Old Dec 12, 2025 | 07:09 PM
Tampa Jerry's Avatar
Tampa Jerry
Got mine at Van Steel. Local for me. They are located in sunny Clearwater, Florida. Depending upon where you live, may be an excuse to pick them up in person and spend a few days at the beach. Jerry
Old Jun 3, 2026 | 08:46 AM
2coupes-67-01's Avatar
2coupes-67-01
Hi Jerry,
My name is Wayne and I live in Tampa so we may have met at car shows. Ive owned my Yellow 67 Coupe for 30 years now and feel the need to rebuild or replace my brake calipers. Are you still a fan of Van Steel? If not, who do you recommend? I also hear good things about Lone Star and CSSB.
Thanks for your help,
Wayne
Old Jun 3, 2026 | 11:19 AM
Tampa Jerry
Wayne: See my other reply to your post about brakes. Jerry
Old Jun 3, 2026 | 06:12 PM
2coupes-67-01
where do I find your reply?
Old Yesterday | 08:09 PM
Pboyd's Avatar
Pboyd
I think all the kits are made by a machine shop in Massachusetts that supplies o-rings not compatible with DOT-5. Replace the o-rings with o-rings made of EPDM rubber and you can use DOT-5 silicone fluid if you prefer
Old Today | 07:48 AM
66/427's Avatar
66/427
From: Born and Raised in South Detroit (Windsor) Ontario
Default o rings
Morning....Pboyd would you have a item# associated with the EPDM o-rings and whom to obtain these from, and ID and OD of said rings would be appreciated. Thank you
Ric
Old Today | 02:43 PM
Pboyd's Avatar
Pboyd
Ric
The size number of the front caliper O-rings is AS568-325. The rear is AS568-318. You can get them online at theoringstore.com. The important part is the material. They must be EPDM rubber. The best material is peroxide cured EPDM rubber. The size numbers do not specify the material. You must choose the material first, then the size.
To O ring caliper conversion
