[C2] I've had enough. Time to try to fix the drips - Valve Covers and Intake Manifold
Back in September I added some UV dye to the engine oil and wow that was interesting. The UV dye showed up at the passenger side valve cover gasket, it showed oil coming up through one of the valve cover bolts, and the dye was visible in other places on the bottom of the engine! It was at this point that I decided to divide the engine in half (top and bottom) and first replace the gaskets and/or seals in the top half of the engine (valve cover gaskets and intake manifold gaskets/seals) and see what affect the new seals/gaskets have on the oil drips that have frustrated me for so long, but some of you know that I’m not mechanically gifted and have been hesitant to start this project because it intimidates me (mechanically).
For a recent snow, the city put down road salt and I used that as my reason / timing to begin some “winter” projects and the second task on my list (the first was to replace all the fan belts) is to replace the valve cover gaskets and the intake manifold gaskets/seals. With the fan blades and the alternator already off the car (fan belt project), yesterday I started the disassembly – to remove the valve covers and the intake manifold.
I’ll share my progress, lessons, and mistakes with the forum and along the way ask you guys to provide suggestions, advice, warnings, tips/tricks, etc. I already made one mistake… yesterday when pulling this metal vacuum line off the passenger side of the carburetor… When it finally broke free the metal line scratched the top of the valve cover
. So there’s mission creep #1 (repaint the valve covers). Tip to myself and for others: protect any / all surfaces that you don’t want to repaint BEFORE they get damaged..
I plan to remove the valve covers before removing the intake manifold but there are still some things that I need to remove before I can pull off the valve covers; for instance: the power steering and alternator bracketry, the metal fuel line coming up from the fuel pump, the throttle linkage rod, the spark plug ground leads. I sure wish that power brake booster and master cylinder weren’t there. What else should I remove before pulling the valve covers?
UV dye coming up under a valve cover bolt
UV dye drip on the bottom of the starter
UV dye drip on the bottom of the inspection cover
These are the valve cover gaskets I plan to install
Pulling this vacuum line out I scratched my valve cover (uurrgghh)
Still have some things to get out of the way before I can remove the valve covers
This is what my engine bay looks like right now
Popular Reply
I'm probably wasting my time here and speaking to "deaf" ears BUT...you may be opening a can of worms that you wish you hadn't. There is nothing "wrong" with your car as it is. The machining tolerances on these 60 year old cars was nothing like it is on modern cars...they leak...that's just what they do. You can minimize some of the leaks with proper torquing of fasteners, some chemical additives and simple wiping down of the areas that will, inevitably, seep fluids. You'll drive yourself nuts trying to "seal up" one of these old classics. The more you drive her the better she'll operate.
Certainly your car and your choice but....
Darin
Compared to my car, OP's is tight as a drum and I am fine with mine. It's old, it leaks, so what. And the can of worms you mentioned has already been cracked open as he's having to repaint valve covers. What's next.
I've got to try, and just think of all the learning I'll accomplish along the way! <<< that's my positive attitude haha
Yep, it is very possible that I'll never stop all the drips but I'm going to try.
I think it's good for the car... engine etc. I keep it on a lift and probably once a month wipe down the underneath just to keep the dirt off. Usually find a drip or two.... maybe the size of quarter every 6-months. They leak fellas!
Ted
Oh and by the way my car does not leak
with a survivor 427 those leaks kept a lot of stuff from rusting all the way back to the dif
valve covers
use the technique above
Non acidic rtv
solvent like brake cleaner
not mineral spirits to clean metal surfaces
you are going to coat the ridge in the head and mating side of the gasket
thats making you seal with barely tightened bolts
same process on the oil pan
intake can be a real bugger you have coolant passages as well, are you sure you had oil leaks from the intake???
