Summit Racing LS3/C5 Time Attack Engine Build
For 2026 I am building an engine with the help of Summit Racing, Cometic Gaskets and Klotz lubricants. The class rules for Max 2 limit NA engine displacement to 6.4L or less. This makes an LS3 build the perfect fit. I found an L92 truck block to use as the base for the build. Then we are going to fill it with the full line of Summit Pro LS parts (crank, rods, pistons, cam, etc)! I will be documenting the process in here with all the parts used. Our goal is to make 550 wheel hp on pump 93 octane. The basic outline will include around 11.5:1 compression, TrickFlow 280 heads, short runner intake and a cam and valvetrain capable of around a 7500rpm redline.
So far all I have is the block. Since the L92 is a truck engine with DoD/AFM, I had to plug the towers in the block the oil flow. I tapped the holes for a 3/8-24 set screw vs the hammer in plugs or rivet type kits. I used the BTR plug kit in my Gen V truck AFM delete, but I like the more mechanical retention of threads for this engine.
Next, I dropped the block off at Cragon Automotive, a shop around here that does a lot of Chevy and Corvette work. They are going to clean it up, line hone, bore, deck etc. Stay tuned for more updates as the progress moves!
https://cragonautomotive.com/
Popular Reply
Convert to 24x reluctor?
This is going to be a fun one. I think many of us have been following the journey of this car for years.
I'm following your build, as I have a very similar one myself, albeit iron block. No dyno yet, but I am hoping after the BTR Trinity install I am also in the mid 500s
408ci
11.3:1
TSP Brawler Series LS3 heads (stainless valves)
Johnson linkbars
Sum 8721R1 cam
90mm TB
1 7/8 headers, 3" x-pipe, z06 Ti's
I wanted 7500rpm, but I am settling for 7200 and shifting at 7. I've seen a few 4.8 crank/rod combos in 6.2 blocks- that might be an engine I go for when then this one pops, because rpm is fun
I found the block on FB marketplace. It came with a Camaro the guy bought but wanted to keep his car old school with a big block. I dont know the history or anything about it, but the bores are still stock and looks like it will clean up well.
408ci
11.3:1
Johnson linkbars
Sum 8721R1 cam
90mm TB
Two things.
Do you have a CCW crank on tap? My knowledge comes from YellowBullet and Bret which suggests more miles and seasons between rebuilds as well as better rpm capacity.
Second thing: Haltech Rebel LS is basically an R3 at half price or less which also includes a harness. $1400 I think at my last check around black Friday? One hell of a deal.
The only differences between R3 and Rebel were related to boost functions. I have an excel sheet somewhere on it.
Two things.
While the rebel is a good deal at $1500, its about $1499 more than I have extra in this build budget, lol.
Your point on the ccws. That is why the 402 is what it is. I could not at the time find a CCW with a factory stroke which was not also a $5k custom order.
I think an :LS2 valley cover will seal the DOD crap, but plugging certainly doesn't hurt.
Good luck
Yes, pretty close! RPM is definitely fun! I am going with the larger heads, short runner intake, and SUM-8744R1 cam to make this more of a top end engine. Since we are "displacement limited", allowing the engine to spin more will make more power up top. For road course use, it will just shift the powerband up. Using the short runner intake will sacrifice some torque down low, but in the 200tw tire classes its already difficult to dig out of the slow corners with less traction. Even the big cube cars like Ryan Matthews and Justin Peachey are using short runner intakes.
Re: capping the oil lines on a newer block for DOD... I have a National A-37 bearing sitting on a shelf at home. They're $15 on Amazon and if you break it apart the rollers are apparently the PERFECT size to block GM oil passages in the galley intended for DOD. Just tap them in with a copper hammer.
Good luck
Something about relying on those little o rings on the Ls2 cover didnt sit right with me on a race engine. Im sure its prefectly fine, but I like the mechanical interlock, lol.
This is what will be going in:
https://www.summitracing.com/parts/SUM-180LS362224
The Summit crank is forged and lightened, and just a few bucks more than a stock cast LS3 crank. I am not concerned using this in the build for a couple reasons. Keeping it stock stroke, there will be less of a moment pushing on the crank than a stroker, and with "only" 11.5:1 compression the cylinder pressure is still lower than a boost application. Being forged its already a stronger material than stock too. But keeping an eye on the bearings like you mentioned is a good idea after each race season.
Good luck with the build, can't wait to see the results!
Rob
