Tuned performance introduction
Old Jan 23, 2026 | 11:03 PM
Tunedperformancedotorg's Avatar
Supporting Vendor
Default Tuned performance introduction
Hello all c4 owners, i want to take the time to introduce myself and services i offer .
my name is Brian, i have been tuning stock and modified thirdgen f bodies and corvettes tuned port injection tpi systems since 99. I started out on eBay and other forums formerly user id Tunedport90 for the last 14 years.. check out my newer website www.tunedperformance.org for tpi parts and your tuning needs from vats deletes to 383-400sbc builds I can help with it all.
__________________
Old Apr 1, 2026 | 12:21 PM
Supporting Vendor
Vats delete sale going on as well as egr block plates.
https://tunedperformance.org/store/p/gm-vats-delete
Old Apr 2, 2026 | 07:11 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Does the vats delete programming disable the alarm system too. Seems like it might/would.
Old Apr 2, 2026 | 08:15 PM
Supporting Vendor
The delete is done in the ecms programming. The change made the ecm will not try detect a hz signal to enable the injectors. There will be no handshake . To fully bypass the vats the starter enable relay get jumped to bypass it as well. Hope that answers your question
Old May 1, 2026 | 04:10 PM
Supporting Vendor
Bump, send in your memcal or purchase a piggyback adapter with the delete.
any questions or diagnostic help feel free to email or pm.
Old May 1, 2026 | 04:13 PM
hessm70's Avatar
hessm70
Quick Testimony- @Tunedperformancedotorg worked with me on my 1988 Pontiac Trans Am GTA before and after a new rebuild. He knows tuning and is very responsive..
Old May 19, 2026 | 06:57 PM
Supporting Vendor
Thank you very much for your support, I’ve tuned a lot of c4s tpi and a few lt1 92-93 vats mostly deletes on those years.
https://www.thirdgen.org/forums/dfi-...rformance.html
Old Today | 07:20 PM
rad928music's Avatar
rad928music
You know when you will be getting the
Holley 58mm Throttlebody 85-88 tpi
Back in stock.
and the:
TPIS Miniram (1204 Ports)
Thanks
To Tuned performance introduction
