C5 Corvettes for Sale Classifieds: Used C5 Corvettes for sale as well as modified or stock Corvettes
FS: 99 Pewter FRC For Sale
Old Jan 30, 2026 | 03:37 PM
fdmech1's Avatar
fdmech1
Default 99 Pewter FRC For Sale
1999 Pewter FRC 111,802 miles. $15K
Car has been maintained through the years, have service records from previous owner.
Car currently has headers into Zo6 titanium mufflers with a Haltech CAI.
Everything (TPMS, ABS,Traction Control,A/C,etc., etc.) works! Only issue is key fobs currently not functioning. Have both keys and FOBs.
Only need are tires (dated out...)
Included is a car cover and set of factory service manuals. Please see below for list of mods/maintenance.
Prior Owner Maintenance:
5/2009 76,250 miles Meziere electric water pump,Comp cams springs,
retainers, studs, pushrods, 1.75 ratio rocker arms, plugs and wires. Retuned.
7/2009 76,500 miles. New GM A/C compressor & belt performed at GM dealer.
12/2009 Column lock bypassed installed. Installed B&M shifter assy., Replaced oil pressure sensor, knock sensors, and intake gaskets.
2/2010 Replaced stock seats with “C5 Sport” seats.
6/2010 81575miles Replaced knock sensors and harness at GM dealer.
4/2011 R&R clutch master cylinder. Transmission replaced with a 33K mile 2002 transmission (owner was experiencing difficulty getting into gear)
9/2011 87,228 miles Shifter shaft realigned and retorqued at GM dealer.
11/2011 87813 miles O2 sensors, knock sensors replaced at GM dealer.
5/11/2016 Meziere water pump rebuilt.
10/12/2016 92,126 Replaced fuel filter, replaced harmonic balancer, all belts and tensioners at GM dealer.
8/2018 Replaced stock mufflers with OEM titanium.
11/2019 101,871 R&R clutch assy (SPEC SC092), Fidanza aluminum flywheel, Tick slave cyl. and throwout bearing. Rebuilt torque tube with Tick kit. Installed DEI tunnel insulator shield. Replaced rear crank seal/cover assy. Replaced rear sway bar end links.
11/2019 Installed 7” Pioneer android stereo, Kicker sub with amplifier.
5/2025 Replaced both cats with Flowmaster high flow cats and replaced O2 sensors.
5/2025 111,101 Replaced all 4 TPMS wheel sensors at GM dealer. Replaced battery.
Under my ownership:
10/2025 111,220 miles Replaced engine oil and filter. Replaced trans and diff fluids. Cleaned throttle body. Pulled and checked plugs ( 30K miles on them). Installed MSD heat sleeves on plug wires. Re tinted door glass. Converted rear brakes over to C6 Z51 new 13”rotors and calipers. Replaced rear tie rods and links. Replaced front brakes, rotors, and calipers. Flushed brakes. Replaced all 4 brake lines with S.S.braided Goodrich hoses. Replaced front sway bar links. Replaced all 4 shocks with Bilstein B8 shocks. Just replaced both front wheel bearing assemblies.
Old Mar 1, 2026 | 05:34 PM
fdmech1's Avatar
fdmech1
Price adjustment, $1K less for new owner to install tires of their choice....
Old Mar 2, 2026 | 06:00 PM
DomC's Avatar
DomC
3rd Gear
Where are you located?
Old Mar 3, 2026 | 09:39 AM
fdmech1's Avatar
fdmech1
Good morning. I am 45 minutes North of New Orleans, La.
Old Mar 22, 2026 | 01:10 AM
kawashikid17's Avatar
kawashikid17
3rd Gear
Hi, love the car. Has the skip shift been eliminated and has the column steering lock been addressed. Lastly, could you provide the vin for the car?
Old Mar 22, 2026 | 01:32 PM
fdmech1's Avatar
fdmech1
Skip shift eliminator and column lock have both been addressed.... PM'd you the VIN
Old Apr 9, 2026 | 06:18 PM
fdmech1's Avatar
fdmech1
TTT Price adjustment.....
Old Apr 16, 2026 | 01:55 PM
fdmech1's Avatar
fdmech1
Video Requests
File Type: mov
File Type: mov
Old Apr 24, 2026 | 11:10 AM
fdmech1's Avatar
fdmech1
Friday bump.....
Old May 2, 2026 | 04:57 PM
Tacoo's Avatar
Tacoo
1st Gear
Hello, i love the car. looking into getting one for myself i was wondering if this one is still for sale?
Old May 3, 2026 | 11:38 AM
fdmech1's Avatar
fdmech1
Yes
Old May 6, 2026 | 08:32 AM
fdmech1's Avatar
fdmech1
UPdate: Came across a set of GM OEM C6 Grand Sport wheels and tires. 285 front 325 rear. Plenty of tread left. Both sets of wheels go with car.
Old May 7, 2026 | 01:33 PM
ygto1's Avatar
ygto1
Nice car!! GLWS
Old May 10, 2026 | 03:25 PM
on track's Avatar
on track
Sharp asf
Old May 13, 2026 | 09:25 AM
SPLATT's Avatar
SPLATT
St. Jude Donor '25
lot of car for that price! GLWS!
Old Jun 5, 2026 | 12:04 PM
fdmech1's Avatar
fdmech1
Bump
Old Yesterday | 08:20 PM
Sunshine60street's Avatar
Sunshine60street
1st Gear
Im interested in coming down from Michigan to buy this, i tried sending you a message but it wont let me. I made just made this account. Shoot me a text at 630-788-0442 if its still for sale. Cash in hand
To 99 Pewter FRC For Sale
