No start after a long drive: Starter or safety switch?
Old Feb 12, 2026 | 09:32 AM
Zanny1's Avatar
Zanny1
Default No start after a long drive: Starter or safety switch?
My 1975 Coupe has been incredibly reliable since I bought it from the original owner 2 years ago. With 43K miles on the odometer (2K by me), the car required servicing and some suspension work to make road worthy..... other than that, jump in and go.
After a 1 hour drive yesterday, in nice weather here in Phoenix, I went to a shop to look at another car I have that is having some major work done to it... way above my pay-grade. Came out, turned the key...... nothing. I could hear a faint click at the starter, all the instruments were functional, noticed a pretty high draw (20A) on the ammeter.... figured he starter solenoid was cooked BUT the shop owner came out and wiggled the AT shift lever around (yes TH400 auto) and the car started right up. Drove home and could not duplicate the same conditions.
I've had the console cover off before to fix the pulleys on the HVAC system... what a PITA to work on.... so before I take it of AGAIN to check the safety switch, are there any thoughts by the community?
Thanks for the help.
Old Feb 12, 2026 | 09:46 AM
interpon's Avatar
interpon
verify all battery connections are tight and not corroded. look careful at wire in insulation
Old Feb 12, 2026 | 10:16 AM
Piersonpie's Avatar
Piersonpie
Especially the negative battery cable ground to frame. Remove the bolt, clean the frame to shiny metal, then reinstall.
Old Feb 12, 2026 | 12:43 PM
ukjohn's Avatar
ukjohn
If just moving the shift lever fixed the problem, it sounds like the safety switch to me
Old Feb 12, 2026 | 01:23 PM
OldCarBum's Avatar
OldCarBum
Ignitions coils can fail when they get hot and will function normally as they cool.
This is usually a sign that they are going bad.
Starter solenoids will do the same when they get heat soaked.
There are solenoids made to take high heat and they have a different colored cap to indicate they are made for high heat.
They are available from many forum vendors.
Old Feb 12, 2026 | 02:17 PM
sunflower 1972's Avatar
sunflower 1972
Brown cap solenoid. Used on just about every GM car in the 60's and 70's.
Old Feb 12, 2026 | 04:48 PM
Haggisbash's Avatar
Haggisbash
Does it start normally when cold? I had the same problem and it turned out to be a worn ignition switch. Could equally be the safety switch too. If you know how to jump the terminals on the starter you can easily verify whether it's the starter or the starter circuit.
Old Feb 13, 2026 | 09:19 AM
Zanny1's Avatar
Zanny1
Thanks for the responses. Will check these suggestions next week and report back.
Old Feb 14, 2026 | 08:58 AM
pltmgr's Avatar
pltmgr
How good is your battery?
Old Feb 14, 2026 | 11:30 AM
Rebelyell's Avatar
Rebelyell
^^^THIS^^^
that's THE FIRST thing to determine.
Go to your local auto electric shop (where they actually rebuild/repair Starters, Generators & Alternators). NOT your local big box parts store.
Your local AES will have a commercial-grade, carbon-pile battery Load Tester. That's the Only reliable method of determining battery condition.
Do it, pay the man; you'll be glad you did.
Old Feb 15, 2026 | 05:30 AM
Dave1977vette's Avatar
Dave1977vette
I had the same problem when my car was hot and it was the starter motor which was heat soaked.
Replaced the starter and no more problems
Old Feb 15, 2026 | 08:44 AM
Zanny1's Avatar
Zanny1
Battery is 3 months old, which of course doesn't mean it is good.
Went out to the shop and started the car yesterday.... all good. Perhaps contacts in the ignition switch were dirty. I sure don't want to take the that all apart.
Plan to jack up the car and have a look at the connections to ground and the starter this next week. Where is the ground cable from the battery typically located? Is there a supplemental cable from the motor to the chassis?
Thanks for the advice.
Old Feb 15, 2026 | 10:53 AM
Piersonpie's Avatar
Piersonpie
I think this should answer both of your questions.
Old Feb 15, 2026 | 12:39 PM
OldCarBum's Avatar
OldCarBum
There is a ground cable that is bolted to the engine block and directly to the chassis.
When I purchased my 73 I had intermittent hard starting issues and it was the ground cable from the battery to the frame as pictured above.
My cables were tight and looked to be in great condition but after I removed about an inch of insulation the cable was green and corroded almost completely through.
After I installed a new cable my hard start issue went away.
Old Feb 15, 2026 | 01:00 PM
sunflower 1972
I'm going with the neutral safety switch just being a smidge out of adjustment.
Old Feb 15, 2026 | 01:06 PM
OldCarBum's Avatar
OldCarBum
Hopefully the OP will post his results when he gets the problem solved.
Old Feb 15, 2026 | 10:23 PM
Rebelyell's Avatar
Rebelyell
you said it.
When battery has great capacity, it often can & will overcome poor connections/corrosion Inside insulation; until it can't.
To No start after a long drive: Starter or safety switch?
Old Feb 16, 2026 | 08:56 AM
Zanny1's Avatar
Zanny1
Thanks everyone for the great suggestions. Will get to inspecting the car this week and report back.
Old Feb 18, 2026 | 08:21 AM
Zanny1's Avatar
Zanny1
Had a good look at everything, except the safety switch, yesterday.
Ground cable between the starter and the motor mount was loose. Cleaned and tightened all the connections.
I am leaning towards the safety switch being out of alignment....putting the shift lever in neutral and moving the lever slightly forward, the car starts just fine. Moving the lever slightly rearward and no contact made, i.e. no start.
Drove the car 50 miles and did not have the same problem starting the car in park. Summer will be here soon, which will probably indicate if heat soak is a problem or not. The wires going to the starter all looked good, including the fusible links.
I don't want to remove the center console cover, having done this before.... but will do so if the problem persists.
Thanks for the detailed information.
Old Feb 18, 2026 | 09:44 AM
ukjohn's Avatar
ukjohn
I'd leave it alone if it starts reliably in Park (or neutral with a little wiggle). There are separate contacts for the 2 positions, the neutral one may just be a bit worn.
