I have a 66 coupe & a 66 Vert. I upgraded both to dual master 1" bore non power. Both are L79. everything is new (but pads), calipers rebuilt, etc. One has much better pedal feel and stopping power. The other has a somewhat lesser feel and requires more effort. No air in the lines. I have no clue what pads are in either car. The coupe I had since 1986 and don't even recall when or what pads I put in, the vert I bought as a roller 4 years ago and I used the pads the guy gave me.
Has anyone upgraded to a brand of pad where they have seen an improved stopping power? I think since all things are equal but the pads, I'd start there.
That was my next question, ceramic or semi metallic.
Non-ferrous ceramic brake pads are premium friction materials composed of ceramic fibers, fillers, and non-iron binding agents (often including copper or brass). Designed for luxury and passenger vehicles, they provide quiet operation, minimal, light-colored dust, and excellent heat dissipation, making them ideal for daily, comfortable driving. Key Characteristics and Benefits
Composition: Unlike semi-metallic pads (which use iron/steel), these use ceramic compounds that are lighter in color and non-abrasive to rotors.
Noise & Dust: They are known for being extremely quiet, with very low noise, vibration, and harshness (NVH).
Performance: They offer consistent braking over a wide temperature range and are generally more durable than organic pads.
I did a total brake system change to all stainless steel on my '66 Coupe with non power brakes. Master cylinder, brake lines, parking brake hardware and calipers. It was filled with {purple) DOT 5 silicone brake fluid as required. My pedal feel was very different than the old factory system. A very hard pedal. Do you have the same fluid in both systems? Did you mix different grades together?
Funny you bring that up....On the coupe I changed to DOT 5 with stock master around 13 years ago...everything flushed and rebuilt. Very hard pedal. Last few years right front caliper was weeping making a mess. rebuilt several times, couldn't stop it. Got two new calipers same problem. At that time )last winter) I decided to go back to DOT 3 and dual master. I too had SS lines. I could not bend the rear line to the new master location so put a new steel line, flushed all other lines, rebuilt remaining calipers and bought a brand new SS sleeved caliper for the weeper from CSSB (great people) and finally I have no leaks but again, the pedal feel is different and braking is less effective. I also felt the DOT 5 braking was lacking although hard pedal. No question all DOT 5 has been flushed completely from the system.
All stainless steel lines, same DOT 5 fill since 2007
3 of 9 cars on DOT 5 in the motorpool.
DOT 5 can seep or leak where DOT 3 may not, but, its performance under pedal is no different than that of DOT 3 provided DOT 5 system is thoroughly bled. It can be harder to bleed if it is not understood that bumping or shaking the bottle aerates the stuff which tends to stay in suspension longer than bubbles in DOT 3. Once a DOT 5 system is bled it will function no different than 3. Lots of other variables, pedal leverage, master and caliper bore, travel but not DOT 5. When using 5, buy a bottle a couple weeks before and let it sit on the shelf quietly until needed. Then, pour slowly. Do that and you will be AOK.
If you have stainless lines you may find a DOT 5 fill requires you to mend some connections, but once mended it will stay dry and fresh ... for ever. It's worth it.
Dan
When I installed my drum brakes to the SS lines , they leaked .
After a little research I learned to tighten them and then loosen and retighten several times to seat them properly .
Not to take this too off topic, but does anyone have any experience with Hawk brake pads?? LOTS of promises in the sales lit and kinda spendy?????
And, put a small dab of grease on the back of the flare so it doesn't get galled by the nut.
I am here reading because my dad's 65 has newer calipers (3 years old) and the mech can't stop the leaks. I assume it is DOT3 / 4 . All new lines and brakes basically. I don't understand why this issue on these cars. What is it about older cars that brakes are so different they leak? Even I can work on modern cars and not have leaks...
So I have this car with almost new calipers (65 conv 327) and my dad says we should put stainless steel sleeves in them. I don't even know what that is or how it would help. Is that the right next move? Or just get new brakes with a better design that doesn't leak from basically new?
Thanks for any advice..
You would do well to ask this post and replies to be made into a new thread -- ask an administrator if that's doable.
Dan is absolutely correct that you need to isolate where the issue(s) are coming from. The vast majority of us have leak-free brakes using the original system design, so it's not a failure in that regard.
Stainless sleeves are something done by an outside company that specializes in these things. Lone Star and CSSB (Corvette Stainless Steel Brakes) are two commonly recommended sources. Unless your calipers are GM replacements from the 1980s or before, I'd bet they are already sleeved. Sleeving is done to restore a pitted original cast iron bore to specs and it resists rusting & pitting in the future. You'd know if the bores are pitted and seals leaking if the fluid is coming out in the middle of the caliper where the pistons are located.
If your new lines are stainless steel, they are known to be challenging to obtain good seals. Stainless is a harder material than the regular soft steel so doesn't conform to the mating seats as well – leading to seepage. If that's where you're getting leaks (any hard or soft line connection), consider a small copper cone washer to make better seal connections. Someone will provide a link to what's needed.
