Fuel pump whine in hot weather
Whine sound that changed in pitch when turn signal on, sounded like the sound effect of the 1960’s Star Trek space ship.
Got out of car and left it running and it was from driver’s side tank.
Went back home in bad freeway traffic got off freeway on my road and engine started stumbling, just barely rolled into a Chevron gas station.
Gas tank wasn’t showing empty.
Put gas in it and drove home, still made that sound.
Tried Techron concentrate plus and it’s not done it again, still on factory pump, jet pump, fuel filter that I am aware, or let’s say the same stuff since April 2003 when I bought the car with 38,000 miles, now at 96,000.
I think there was a chunk of something clogging the jet pump, same crud that made the fuel sender read incorrectly.
Try some Techron concentrate plus, couldn’t hurt.
Run a few treatments through or at least 2, if it doesn’t fix it, still not wasting $$ to clean the intake valves and fuel injectors, etc.
I agree that if you haven't you should change your fuel filter. A failing pump can send debris to the filter. I always change them as a pair.
With the car idling and the symptom present, what happens if you remove the gas cap?
Noise sounded like an air-raid siren - very loud... and it pulsed with the turn signal.
I also smelled gas.. so I assumed the pump was dying.
I had a shop install a new fuel pump and was able to drive the car home... but THE NOISE RETURNED about 1/2 way home!
Since then I have cleaned the ground point in the rear wheel well - both the fuel pump and rear lights share this ground. It was mostly painted over with black chassis paint.
I'm also going to change the fuel filter as it's been over 50K miles.
Here is a link to the thread I started on this, including video of the noise and photos of the ground point: https://www.corvetteforum.com/forums...-the-pump.html
I did decide to change the fuel filter.. I cut the old one open.. It looks a little gritty.. Possibly clogged?
Second suggestion is probably too much of a science project....rig up a fuel pump so that the pump sees a normal input and output of fuel. Does it still whine when you power it on.? I have a power supply with a variable voltage output. I'd run the pump at voltages ranging from 12.0 vDC to 14.5 vDC to check out the noise situation.
Apologies for not being much of a help. Interesting problem for sure.
Also, removing gas cap when noise is present has no effect. It's not pressure or vacuum in the tank causing it.
