1992 Corvette LT1 – Intermittent dash failure + no crank + runs on spray… need expert
Here’s exactly what it’s doing:
The dash is intermittent. The center display (odometer/DIC) and left side will randomly go dead, while the right side and accessories (radio, windows, etc.) still work. When the dash is dead, the car will NOT crank at all. When the dash comes back to life, the car will crank again.
It almost acts like it’s on a timer. I can sit with the key in the run position, everything on the left side shuts off, no crank, then after a little time it comes back on and I can crank again.
Fuel side:
Fuel pump primes and has power. Fuel is making it to the rail. Engine will run on starting fluid every time, but will NOT run on its own fuel.
Injector side:
Injectors have 12V (pink wire confirmed), and I do have injector pulse with a noid light.
Electrical checks so far:
Battery and main power are solid. Ignition switch tested good (orange constant and pink IGN both have proper voltage). All fuses check good except the INST fuse (3A), which never gets 12V. Both sides of that fuse show ground with key on. I even tried feeding 12V into that circuit and it didn’t bring the dash back.
Other clues:
Dash has flickered back to life briefly a couple times, including the odometer lighting up, then dies again when the key is cycled. When the dash is dead, I also get no crank. When it’s alive, I get crank.
Where I’m at now:
Feels like either a cluster/CCM/VATS-related issue, bad ground, or a broken feed to the INST/dash circuit. At the same time, since I have injector pulse but it only runs on spray, I’m also considering low fuel pressure or clogged injectors.
So it almost seems like I may have two issues:
- Dash/CCM/VATS circuit killing crank intermittently
- Fuel delivery problem (pressure or injectors)
Has anyone seen this combination before on a C4 LT1? Especially the dash acting like a “timer” and killing crank?
Any direction on where to go next would be huge.
Update / additional detail:
When the dash is actually lit up and I’m able to crank the car, the RPM gauge does NOT move at all while cranking—it stays completely flat.
Also, the security light behaves normally (flashes like it’s supposed to), so I don’t think this is a VATS/key issue disabling the car.
So even when I have crank and injector pulse, I’m not seeing any RPM signal on the dash.
Spent a lot more time on this today and I’m still chasing this down. I want to give an accurate update and also make sure I’m reading these codes correctly.
These are the codes EXACTLY as they flash on the dash, in order, every time I pull them:
- 1 – H54
- 7 – ERROR
- 9 – H72
- 1 – C12
- 7 – ERROR
- 9 – H72
- 1 – C12
- 7 – ERROR
Am I reading this wrong, or is this actually what the car is outputting? The “7 – ERROR” part is throwing me off, and I want to make sure I’m not misunderstanding the display.
Current symptoms:
- Car cranks strong every time now
- Fires right up and runs smooth on starting fluid
- Fuel pressure is confirmed good
- Injector pulse is confirmed with a noid light
- But it will NOT run on its own fuel
Earlier plugs were dry, which makes it seem like injectors are not actually delivering fuel even though they have pulse and pressure.
Dash / electrical side:
- Odometer does not display properly (just shows 0 or incorrect data)
- “SYS” has shown intermittently
- Dash has had intermittent dropouts/resets
- Occasionally hear a click and the system seems to momentarily reset, then come back
Where I’m at:
It feels like I may be dealing with two separate issues:
- Engine side → injectors possibly clogged or not flowing despite having pulse and pressure
- Dash/CCM side → communication or circuit issue based on H54 / H72 / ERROR and the display problems
Main questions:
- Am I interpreting these CCM codes correctly, especially the “7 – ERROR”?
- Has anyone seen this exact sequence before?
- On the engine side, has anyone seen LT1 injectors pulse normally but not actually flow fuel like this?
Any input appreciated. Trying to narrow this down without throwing parts at it.
Yes, the Service Engine Soon light does come on with the key in RUN.
I also already tried pulling ECM codes using the flash method (jumpered A & B) and all I get is Code 12 repeating, so it doesn’t look like the ECM is storing any fault codes.
That’s part of what’s confusing me—because I’m still getting H54, H72, and the “7 – ERROR” on the dash, along with zero RPM while cranking and no fuel delivery.
Also worth noting, the left side of the dash (security light and LCD) will randomly shut off completely and when that happens I get a no-crank condition. Then it’ll randomly come back on and crank again. When it drops out I can hear what sounds like a click from behind the dash.
Does that still point you toward ECM failure even with no stored ECM codes, or would you be looking somewhere else next?
I probed both sides of each fuse individually, not just one side, and I checked them in both conditions—when the dash is working normally and when it drops out and I get the no-crank condition. I’m using a power probe so I can clearly distinguish 12V vs ground.
In all cases, I have solid 12V on both sides of each fuse, and that does not change when the failure happens. I’m not seeing any loss of power at the fuse level when the CCM/LCD cycles.
I’m going to attach a photo of the fuse panel as well. The fuse I have circled is a 3A fuse, and I can’t get that fuse to show 12V on either side under any condition—key on, key off, whether the system is working or acting up.
Is that fuse ever supposed to have power, or is it only active under certain conditions?
For context, I’ve never had this car running—I bought it from a donation auction about two weeks ago, so I don’t have a known-good baseline.
Does that line up with what you were wanting me to verify, and would you now be leaning more toward a ground issue or the CCM itself cycling/resetting internally?
EDIT; It's not the CCM, it is not the "grounds".
I’ve also gone through and shaken, pushed, pulled, twisted, and generally stressed the fuse panel and all of the known ground points under the hood. I was able to find the ones you mentioned there and they all look clean, tight, and in good shape.
I haven’t checked the interior ground points yet, but I’m going to go after those tomorrow now that you pointed me in the right direction.
Also, when I was testing the fuses I had my power probe/test light grounded directly to the battery negative.
Thanks again for taking the time to reply, I really appreciate it. I’ll get an update posted tomorrow after I go through those interior grounds and hopefully we can narrow this down further.
I’m attaching photos of the module and the area it came out of so you guys can confirm I’m working with the correct component. That was a job in itself getting it out.
I opened it up and didn’t see any obvious signs of damage—no burnt components or anything that stood out visually.
I reinstalled it loosely and powered the car up so I could access it, then tried wiggling the connectors and harness to see if I could get the issue to trigger or change, but I didn’t notice any reaction.
I also checked the interior ground points at both driver and passenger kick panel areas. They look clean, tight, and free of corrosion. I loosened and re-tightened them just to be sure.
At this point, I’m trying to determine if I’m on the right component here and whether this is pointing more toward an internal CCM issue or if there’s something else I should still be checking before going that route.
Man, I’m honestly pretty stumped at this point. I was really hoping to find something obvious or something that stood out once I got this far into it.
I’ve got a lot of this car opened up right now—dash apart, panels off, modules out—and everything looks surprisingly clean. No corrosion, no obvious damage, nothing hacked up. The car only has 60k miles and was a one-owner car before it got donated, so I feel like I bought a can of worms that shouldn’t even exist on something this clean.
I know I’m missing something, I just haven’t found it yet. Any help or ideas would be seriously appreciated—please keep the suggestions coming. I’m working through this the best I can, but I’m definitely limited in certain areas and trying to learn as I go.
Driver side ground
Passenger side ground
Area behind hush panel driver side
CCM?
IHBD mentionned to check the grounds for that module (G106) but mentionned that it's located on the bellhousing. That is valid for the LT5 but for the LT1 that would be close from the oil filter. Have you checked that one too ? That is the main EBTCM and CCM grounding locations (...and plenty of other things). Some picture from the 93 book, hopefully that is the same on a 92. The picture should help verifying that point.
I know you checked grounds, but just to be sure that you haven't forgotten one.
Also the CCM has a top / bottom side (circuit board). Have you checked the bottom side ?
And yes, I completely removed the circuit board from the casing and inspected both sides of it. I didn’t see any obvious issues—no burnt spots, cracked components, or anything that stood out.
At this point I’m not seeing anything visually wrong with the CCM or the main grounds, so I’m kind of at a loss on what to go after next. What would you check from here?
This is the kind of problems that often turns out to be something really stupid. Let's hope it's one of them!Ok I trust you on the ground checks. I'd like to take the time to thank you for explaining clearly what your problems are, this is rarely the case on this forum, we often get half of the explanations and also, half of the proposed solutions are tested.
So back to the problems ! Let's ask more questions :
- You said that the LCD / display / bulbs turn off by themselves after putting the key in run / buulb test and just waiting, right ? So basically under light battery load, without cranking.
- You said that it happens after a specific time ? Can you keep track of the time ?
- Can you trigger the issue earlier by slamming the door or just shaking a bit the car when the key is in RUN?
- Can you play with the dimmer (up and down) to stress a bit the interior lights and LCD backlighting when key is in RUN?
- Do you hear the chime when the key is in RUN ?
- Do the interior light flicker from time to time ?
- Yes, the LCD/display/backlighting will shut off on its own with the key in RUN, no cranking, just sitting there.
- I wouldn’t say it’s on a specific timer. It feels random. Sometimes it happens quickly, sometimes it takes longer.
- Opening/closing the doors or shaking the car doesn’t seem to trigger anything. I haven’t been able to make it fail that way.
- I actually haven’t paid close attention to the interior lights, so I’ll need to check that specifically and report back.
- As far as the chime, I don’t get a normal consistent chime like you would expect with the key in the ignition and door open. The only time I’ve really heard anything is occasionally right when I reconnect the battery, I’ll get a very quick, random chime for a split second.
One thing that might be worth mentioning—there have been a few times where the dash has randomly come back to life after I did something unrelated electrically. For example:
- Disconnecting the jumper wire from the ALDL port once made everything come back on
- Another time I was pressing buttons on the climate control (fan speed/off) and the dash came back on
- I also remember disconnecting the fuel pump in the back and it seemed like the dash came back at that moment
I originally thought all of those were just coincidences, but now I’m starting to wonder if small electrical changes or load changes are triggering the system to wake back up.
When the failure happens:
- Security light goes out completely (no flashing)
- The light above it goes out
- LCD goes dead
- No crank
All other electrical systems seem to continue working normally.
Also worth noting, the security light behavior isn’t always the same. Sometimes it flashes in what seems like a normal pattern, other times the pattern looks different, but I haven’t been able to find a consistent pattern to tie it to the failure.
But thinking about your questions, I do feel like some of those small electrical changes I mentioned earlier (disconnecting something, pressing buttons, etc.) may have actually triggered it to come back to life rather than causing the problem.
Also, most of the time when I first go out to the car—especially in the morning—the dash won’t power up at all. I usually have to sit there messing around with things for 15–20 minutes before it finally comes alive. Occasionally it’ll work right away, but that’s rare.
Once it does come on, sometimes it’ll stay on long enough to actually do some diagnostics, other times it’ll shut back off again pretty quickly. It feels very inconsistent and almost like it’s deciding when it wants to work.
Not sure if that helps or not, just trying to share as much detail as I can. I really appreciate you guys taking the time to help with this.
When you loose the instrument cluster, check the interior lights if they also flicker or completely turn off.
Try to enable the headlight and then the high beam (another feature partially linked to the CCM) and see if the high beam indicator (blue on the cluster) also goes off.
Same for the fasten seatbelf indicator.
